well here they are...painted fogs...
sorry the pics took so long...just got done installing them...believe it or not had a water leak where the bulb goes into the housing...at least my seals held up...so i had to wait until today for the lights to dry out completely before putting my hids in...(they are 6000k from hid4u, still have to get my headlights) the install was simple...tho for added safe measure i put a small bead of rtv sealant around the base of the bulb where it meets the housing to ensure a good seal...here are the pics...
3 coats of krylon gloss
best spot i found to install ballasts...used the supplied tape and cant budge it...plus least likely to get water...
finished shot
finished shot
x2. if its not that bad i might do the same thing.
yeah im going to paint my headlight hopefully this weekend....wanted to try it out on a less expensive part first...in person they look alot better...it was a little hard to get a shot with the sun glaring but....ill take a shot of them tonight so you can see light output
FINALLY!!! lol..
they turned out good! i'm going to have to rip mine apart and paint mine as well... however, ill be doing it somewhat differently... i plan on leaving the chrome fins chrome, and painting the top and bottom of the lense, as well as the flat rim around the entire thing.... it's kind of hard to explain, but you'll see.
Nice job!
Nice job!
thats true but you would have to put a lot of night-shade on it so it wont look green, clear lenses look green if u dont put enough niteshade on it. doing this would probly give about the same output of light.. i could be wrong.
FINALLY!!! lol..
Nice job!
Nice job!
yeah but niteshades would have looked like a$$....they look 100x better painted...like i said before i have 2 sets of kc fogs so im not worried about light output
