Removal of tow hooks/bull bar
Old Apr 1, 2008 | 08:53 PM
gators241987's Avatar
Is there any way possible if you remove your tow hooks, to put them back in there? i got the back bolt in, but i cant thread the front one in. if i went with a bull bar, would me not being able to get the front screw in matter?
Old Apr 2, 2008 | 01:38 AM
RightTurn's Avatar
well i wouldnt want to drive around with only one bolt holding it on, thats for damn sure.
Old Apr 2, 2008 | 01:55 AM
FX4life's Avatar
Im kinda confused? I thought you lose the tow hooks when you put on a bull bar? I also dont think the tow hooks would be of much use with only one bolt holding them to the frame?
Old Apr 2, 2008 | 01:57 AM
RightTurn's Avatar
yea you do loose the tow hooks, but he is trying to put his back on with the bull bar.
Old Apr 2, 2008 | 02:13 AM
FX4life's Avatar
I see...sounds like drilling out the bull bar for a socket would be a good idea, Maybe?
Old Apr 2, 2008 | 02:51 AM
Tylus's Avatar
he's asking how to rebolt the tow hooks, not how to run them with a bull bar also
on the inner side of the frame rail there is a slot that is just big enough for your hand to fit into. loosen the back bolt just enough for it be barely engaged. then using one hand, reach inside that slot and push the bolt bar so that it aligns with the holes in the frame. thread in the front bolt. you may need a screwdriver to help align the holes while your pushing around with your hand
btw, when I installed my bull bar, I re-used the OEM bolts because they were alot more heavy duty than the stuff that came with the bar.
hope my explaination helps. I feel your pain. it took me about 5 minutes of fumbling to do it
Old Apr 2, 2008 | 05:59 AM
risupercrewman's Avatar
Your exactly right! You need to align the bolt bar & hold it in place with a screwdriver while threading the bolt......I did this when I installed my Go-Rhino push bar!............
Old Apr 2, 2008 | 10:00 AM
tnsilverfx4's Avatar
Does anyone know how to run hooks and bar? I know a few people in here have said that they made it work.
Old Apr 2, 2008 | 06:16 PM
jimmy k's Avatar
may need longer bolts. I had to do just that with my Smittybilt bumper guard
Old Apr 2, 2008 | 06:20 PM
Im not seeing this area. inner side, so since when you face the truck in the front, my missing bolt in on the left tow hook, so it should be on the right hand side of the missing bolt tow hook side? theres no area for my hand to fit in.
Old Apr 2, 2008 | 09:13 PM
I had to fish around for it when I lost it several times with a screwdriver end! It takes patience & a steady hand...........
Old Apr 2, 2008 | 10:38 PM
Tylus's Avatar
whoa, I feel like a total monkey's butt. I went out and looked at my truck and realized I was talking about the 92-96 F-150's. These trucks don't have that slot. Sorry
okay, nix the whole finger part, just use a screwdriver and wiggle that back bolt around. you should be able to see the bolt hole line up if your careful and use a flashlight.
It can be done, just a little patience required
Old Apr 2, 2008 | 11:17 PM
Haha, its ok. I will have a look at it this weekend. I was like hmm, do i have a special f150 that has a fully boxed frame horn? sawwweeeetttt
