4x4 Question
I am considering buying a 2006 F150 5.4 4x4 with 22,500 miles. While checking out the truck I noticed when switching from 2wd to 4wd High a light on the instrument panel lights up. But when I switch the truck to 4wd Low the light goes out and nothing shows up. Is this normal or could there possible be something wrong with this truck? Thanks
Truck was parked
Truck was parked in parking lot. Did not put in neutral positon. Shifted from park positon. Backed up some then back forward and tried again. Still no 4wd Low light.
Thanks guys! I will go back and check it out. Will let you know the outcome.
Truck was parked in parking lot. Did not put in neutral position. Shifted from park position. Backed up some then back forward and tried again. Still no 4wd Low light.
Originally Posted by YOMAN
wait a minute...just realized something.
I think your suppose to press BRAKE pedal while its in "N" then switch to 4Low ?? i m not sure but double check..
YOMAN!
YOMAN!
