Bought a new 2008 Lariat 4x4 Crew- Needs some advice!
Old Feb 10, 2008 | 12:49 PM
Dian's Avatar
Question Bought a new 2008 Lariat 4x4 Crew- Needs some advice!
So I purchased a new 2008 Lariat 4x4 a couple of days ago. I got it with with black leather interior and the 40/20/40 bench seat up front instead of the captains chairs with center console (I like the extra leg room and seat better). I traded in my old 2004 STX 4x4 Supercab for it, and I'm realy happy with it so far. I need some opinions on a couple of things though.....
1.) I want to have it lifted up a bit and a set of 35" BF Goodrich tires put on. The guy at the shop here recommended using a leveling kit.... 3" up front, and 1" in the rear, to raise it up. I'm wondering if using a leveling kit is such a wise idea on a new truck instead of a standard lift kit. Any advice?
2.) I have an Edge programmer left over from my last truck. Will it work on this new one? And if not, how will I adjust my speed for the new tire size I'll have?
Thanks in advance for any advice you guys can provide! Pics are soon to follow!
Old Feb 10, 2008 | 12:58 PM
2006M50B's Avatar
1- congrats on the new ride
2-I would recommend an actual lift over leveling kit-front leveling kit is nothing more than a spacer (correct me if im wrong) for the coils and if there is to much lift it screws up angles on the CVs or whatever is they are called and in future will ruin them and now you have to replace
3-sorry I dont think i can be much help with the tuner-you may want to call the company you got the tuner from and ask them, but I think the edge can be used in differant trucks if it isnt custom tuned
Old Feb 10, 2008 | 01:10 PM
johnnyd2723's Avatar
I'm not sure but I don't think the guy at your shop knows what he's talking about, 3' up front? Holy smokes!!!
j/k
Old Feb 10, 2008 | 01:18 PM
gators241987's Avatar
congrats on the truck!!!
1. Get a lift kit instead of level kit. It will be better for the truck
2. The edge will still work
Old Feb 10, 2008 | 03:32 PM
dsq3973's Avatar
Congrats on the new truck. Where are the pics man!!!!!
Old Feb 10, 2008 | 04:01 PM
PHS79's Avatar
Congrats on the new truck!!!
1-If you are going to be going out 4Xing with the new truck then I would go with a actual lift kit since it will give you better suspension geometry which equals more flex and wheel travel. But if you are just looking for a way to put 35's on and the truck is going to see very limited if any off road use then you can go with a leveling kit. Some people say that leveling kits will eat ball joints, yet others have had kits on for over 70,000 miles without any problems at all.
If you do go with a leveling kit I would suggest one from the Auto Spring Corp. With either the 2" or 2.5" you car clear 35's, on most trucks the 2" kit makes them sit level and 2.5" makes them slightly nose high. Auto Sping also makes a block kit for the rear so that you can raise the rear if you want.
I personally have the 2.5" kit up front with Firestone air bags in the rear inflated to 20psi to raise the rear 1" and also firm up the rear alittle so that it rides more like a truck. I have had the AS kit in for about 2 years, only 10,000 miles though.
2-Yes you can use your Edge on the new truck, but if I were you I would call Edge with the HEX code off your truck to see if your trucks computer is supported by the software version that you truck has. If its not, you will have to down load the newest one off of Edge's website.
Old Feb 10, 2008 | 04:48 PM
mSaLL150's Avatar
If you do use the edge, grab some custom tunes from Bill. They will be a lot better for your brand new truck than the canned ones that the programmer holds.
Also, do not get a leveling kit. grab a 4" lift kit. Leveling kit will stress your front suspension.
Old Feb 10, 2008 | 07:47 PM
2005lariatky's Avatar
I have seen in a lot of threads that the Edge is not yet compatiable with the 08's.
Old Feb 10, 2008 | 08:58 PM
05RedFX4's Avatar
Same thing last year at this time with the then new 07's. I had an edge on my 05, my 07 was not supported when I got it, so I sold the edge and got an X-cal 2 with custom tunes.
Old Feb 10, 2008 | 10:30 PM
Super FX4's Avatar
I am putting a 2.5" AS up front and blocks in the rear, I know it will fit 35's if using factory wheels. I know it is better to do a full suspension lift bu that costs 10x's as much and dont want to be that high up
Old Feb 11, 2008 | 02:12 AM
Grubrunner's Avatar
Better in what way?
Old Feb 11, 2008 | 12:21 PM
Dian's Avatar
Thanks for all the input guys! Not sure what I shuold do yet, but I'll keep reading here before I make any decisions.
Old Feb 11, 2008 | 03:07 PM
5150steves's Avatar
Put a lift on it!!
