4.10 gears....what would you choose?
Old Jan 30, 2008 | 08:10 AM
JeremyGSU's Avatar
Read post below please.
Old Jan 30, 2008 | 08:17 AM
Smok][n's Avatar
i went with the motive stock replacement 4.10's and am very pleased. im throwing alot of horsepower through them and have done some pretty good towing and they have held up fine. i even installed them myself, so they seem pretty idiot proof. also, you cant beat the price
i was also considering the fords, but the price was the deciding factor for me...
Old Jan 30, 2008 | 08:27 AM
JeremyGSU's Avatar
Smokin, I've read your threads and know you're making some power so if they can hold up for you they can certainly hold up for me.
Can you recommend a place I can buy them cheap? Where did you buy yours?
Hey, also that "Road Track Video" you posted. You're doing a parade lap at Road Atlanta, right? What car club was hosting that event?
Old Jan 30, 2008 | 09:10 AM
Smok][n's Avatar
heres the link for site i purchased them from:
http://nationaldrivetrain.com/shopsi.../ford_975.html
i believe the only other thing i had to purchase was a pinion bearing that i was able to get at autozone for around $30 or so. the mini installation kit has almost everything u need.
the event at raod atlanta was hosted by Year One and they do it every year in may. i have a friend who used to work for Year One and gets me free tickets for entry and for the parade laps. here's a link for the event details:
http://www.yearone.com/yodnn/Default...m/yodnn/Events
if youre free that weekend you should come, its alot of fun. the have all kinds of events like wet autocross, parade laps, hot laps, burnout comp., offroad stuff, mobile dyno etc. ive gone for the past 2 years and plan on it again this year
Old Jan 30, 2008 | 09:19 AM
JeremyGSU's Avatar
Thanks for the help Smokin.
I was just curious because I do a lot of HPDE's and my club (ChinMotorsports.com) is planning on running Road Atlanta this year.
Old Jan 30, 2008 | 09:34 AM
Huitt24's Avatar
How difficult is the Ford 9.75 rear to set gears up in? I have done the 8.8 and 9", AMC 20, Dana 44 and GM 10 and 12 bolt.
thanks
Old Jan 30, 2008 | 09:54 AM
Smok][n's Avatar
thanks
well for me it wasnt that bad, but i think i may have gotten lucky. i didnt do too much as far as checking backlash and pinion depth are concerned. i just put the new gears in with the old shims, checked th contact pattern(looked good the 1st time around) and followed torque specs putting it back together. i tried to set the bearing preload and do the crush sleeve and all that, but i didnt have and inch/pounds torque wrench so i dont know how accurate i was. like i said luckily in my case it all seemed to work out ok, but who knows if it would again...
Old Jan 30, 2008 | 11:25 AM
Motive...
x2 on that Smok][n!
Old Jan 30, 2008 | 02:19 PM
JeremyGSU's Avatar
Well I've talked to a bunch of people today and I found a set of Ford OEM 4.10 gears ring and pinion set for $234.95 today. I'm willing to pay an extra $50 for the OEM stuff and play it safe this time.
Now my question is this. I've called the place that originally installed my gears and they said they would swap them out for $150. However, I've read on some other forums that a lot of people think gear whine is from the installer, not the gear.
Now, I talked to a gear and driveline place today and the owner told me that it can be hit or miss with Precision gears. He said they installed lots of sets with no complaints or no whine but he said they've also installed a good number of sets where there was gear whine and peopel complained about.
That being said, should I let the original place that put in my gears swap in the OEM ones and chance it or pay money somewhere else to installed them?
Old Jan 30, 2008 | 03:28 PM
styxnpicks's Avatar
id give em one more chance
Old Jan 30, 2008 | 08:47 PM
MTpint's Avatar
I read somewhere Motive makes Ford gears, but you cant always believe what you read on the internet. Motive x3
Old Jan 30, 2008 | 08:56 PM
Smok][n's Avatar
yeah i heard that too. at least for some years and models...
Old Jan 30, 2008 | 09:10 PM
mbogosia's Avatar
Registered User
I'm having Ford Racing Gears istalled tomorrow. They are charging me $450 total for the gears and labor. That makes sense since he said it should only take 2-3 hours. I can't wait to have this done, however I am worried about a whine also.
Old Jan 30, 2008 | 09:41 PM
JeremyGSU's Avatar
From talking with many companies about gears most people are in concurrence that OEM Ford gears should have the least possibility of whine out of any gear because it's OEM.
I'll definitely be making the switch because I'm not happy with my Precisions.
Old Jan 30, 2008 | 09:53 PM
mbogosia's Avatar
Registered User
Well, after doing some research it seems that this is one of the things that are all over. I talked to the installer and he said he has had the best luck with the Ford Gears. Supprisingly he told me the Yukon gears seemed to be more troublesome.
