Manual Climate Control to Automatic Climate Control...Anyone Successful??
Old Jan 24, 2008 | 05:34 PM
Buzzz's Avatar
Have you used the auto climate control? You would actually prefer it over the manual? I have owned 6 fords, 5 with auto, one with manual. I would take a manual any day. Simple, easy to get what you want. Auto has too many options makes it cumbersome. Just my 2 cents.
Old Jan 24, 2008 | 09:00 PM
Quintin's Avatar
I like the automatic control. I don't even use any of the manual settings, just leave it on auto and adjust the temperature as needed.
Old Jan 24, 2008 | 09:17 PM
cndcowboy's Avatar
Same, just set the temp and leave it, don't have to worry about fan speeds etc. It does it all for me.
Old Jan 6, 2024 | 10:16 PM
06_4.6's Avatar
Originally Posted by petey305
Thanks for the responses folks,
Ya, I did that, and found quite a few posts. The problem is..NONE of them got past what you mentioned. They all said 'you gotta do this', and the last post is always 'OK, I'll try it and post back results'...then...nothing. No post to success or failure....which I'm guessing is not a good thing.
If I knew this was possible and had some basic instructions, I'd probably be willing to try...Unfortunatly, I don't have the money to burn to chart new territory.
For the EATC, I was able to find this description from some online part dealers:
Dash control unit, f150, mark lt, w/atc, w/o rear defroster, w/o heated seats - f150 new style 2004-07, mark lt - F150 NEW STYLE 2004-07, MARK LT 06-07
but it doesn't give a part number unfortunatly. I'm guessing that's as close as I would get...sounds like the heated mirror button maybe there (another upgrade perhaps?).
I haven't been able to find any bezel parts described.
JP
I know the thread is old but it met the same date y’all didn’t want it to. But I’m here with the same question did it work? Did it not? What happened? And info helps!
