sunk my fx4 f'd it up
Old Jan 13, 2008 | 10:41 PM
Ridinon22's's Avatar
Unhappy sunk my fx4 f'd it up
I have a 05 fx4 screw and was wheeling all weekend well I went thru a hole and dint realize how deep it was until it was to late i got in and couldnt get out started sinking the drivers side front got about 6 inches from the hood and i had water in the cab up to my ankles. I finally got it out after my buddys in a dodge and chevy pulled me out which cleray sucked. When I got out i opened the doors and water came pooring out anyways I drove back to my camp and cleaned out the intake system and filter then began cleaning although being 100miles from home with no vacum it wasnt easy. NOW I have a check engine light on and my tranny is all messed up I think?Everyone thinks my computer needs to be reflashed but I dont know it feels like the o/d isnt working? When you give hard gas the truck revs to 3 or 4K rpms but doesnt go anywhere and doesnt shift untill you let off the gas. any thoughts I'm going to bring into the dealer tuesday I hope they dont void the warranty lol I've been cleaning for like 10hrs P.s. i'll post pics asap
Old Jan 13, 2008 | 10:43 PM
scott1981's Avatar
Get the trans fluid and oil flushed ASAP. Dont take it to Ford with water in it or your screwed for sure
Old Jan 13, 2008 | 10:44 PM
thorherc67's Avatar
holy ***** that sucks but post pics i want to see this. I am sorry man
Old Jan 13, 2008 | 10:45 PM
Jditta's Avatar
That's why I don't go play in the mud.
Old Jan 13, 2008 | 10:46 PM
scott1981's Avatar
Thats why you don't drive 30k vehicles through holes when you don't know how deep they are
Old Jan 13, 2008 | 10:53 PM
PHS79's Avatar
Thats the best reason to have a beater truck around! Anything happens to it and it can sit until I feel like working on it, and then I just drive the FX4 for a work truck for awhile.
Old Jan 13, 2008 | 10:54 PM
i dont belive water got inside the oil or the tranny fluid i checked the sticks and they look good? what else could it be
Old Jan 13, 2008 | 10:55 PM
PHS79's Avatar
With all the electronics on these trucks I would put good money on them.
Old Jan 13, 2008 | 10:58 PM
so your saying you think its the computer?
Old Jan 13, 2008 | 11:01 PM
FX4ME2's Avatar
I would start by unplugging every wire connection that got wet and blow dry them out. I would unplug the battery and clear any codes out of the computor (need a tuner for that) Check all fluids for water, and i would change all of them to be safe.
Old Jan 13, 2008 | 11:04 PM
PHS79's Avatar
It could be, but I think that it is more likely to be some wiring connections that got wet and muddy.
Old Jan 13, 2008 | 11:05 PM
PHS79's Avatar
.X2.
Old Jan 13, 2008 | 11:09 PM
ok but do you guys think i should bring it to the dealer to figure out what codes its throwing i cleaned out the inside real good and spent at least an hour cleaning out the under carraige sooooo should i bring it in and say its throwing codes i think its the tranny and oh yea check the computer if it needs a reflash?
Old Jan 13, 2008 | 11:11 PM
nuclearthreat54's Avatar
WD40 works excellent I heard for that.
Old Jan 13, 2008 | 11:37 PM
NoLongerJeepin's Avatar
i dont think your computer needs a reflash. you probebly have to much mud or crap stuck in the connections by your tranny. get under it with some q-tips, wd40, and a hell of alot of time and clean EVERY connection you can find. then take it to jiffy lube or something and have them change the tranny fluid and oil. including the torque converter fluid. they can probebly check the code as well. after that take it to ford and tell them its slipping up. this way they cant void your warrenty.
