4x4 NOT ENGAGING
Old Dec 17, 2007 | 08:10 PM
RUSS04's Avatar
Originally Posted by red_candle
In 2WD only one rear wheel gets any power, in 4WD only one front wheel and one rear wheel... unless you have lockers or limited slip.
I have LS
Old Dec 18, 2007 | 04:27 PM
RUSS04's Avatar
Originally Posted by RUSS04
Where are all the ford techs on this forum when you need them I posted this in the trans forum but could not or see an answear to my problem I have a 2004 4x4 supercrew lariat with 13600 miles On sat morning we had snow covered roads I pulled out of the garage and put it 4high I took off from a red light and my rear end let loose the front wheels never spun I pulled over to the side put in nutral with my foot on the brake and i put in 4lo The light lite up 4lo same thing no traction on the front axle Iam going to the dealer on monday Any info on this problem that can help me with this before i take it in Would really help Iam glad that i bought a ford esp premiumcare warrenty before my 3 yr mfg ended in oct THANK YOU FOR ANY HELP RUSS04
I just got a call from dealership A part broke in the transfer case They had to order another part What broke ? I have no idea I will keep you all informed
