10% Ethanol
10% Ethanol
So I stooped by my local Hess station the other night and noticed a sign on all thier pumps. It said that the gas contains 10% ethanol in it. I only put in a couple gallons but I was wondering if this small amount can hurt my engine. I was browsing earlier and was reading about the guy who's putting all ethanol in a non flex fuel engine and read what ethanol can do to a regular engine. Just Curious
10% ethanol is used to replace that toxic addative that is turning up in groundwater sources. I think it was called MTBE.
http://en.wikipedia.org/wiki/MTBE
As new as your vehicle is, wouldn't worry about it too much - the E85 stuff is what you need to stay away from.
In the late 1980s, the EPA mandated oxygenated fuels for winter blends in certain markets to forcibly lean out the mix and thereby theoretically reduce HC and CO emissions. The oxygenating compound originally used was called MTBE, and it was an environmental, disaster. In the late 1990s the MTBE was dropped in favor of a 10% Ethanol mixture. Since most regions have at least one fuel market (major city) that has a smog problem, almost all gasoline sold in the United States during the winter months is oxygenated (Contains ethanol) some areas do it year round.
You can expect to notice a fairly sizable drop in gas milage with this, but no real harm done. It's the higher concentrations of ethanol, like E-85 that cause the corrosion problems.
Originally Posted by Stealth
Since 1978 when I was 7.
Originally Posted by Shinesintx
Got ya by one year in age...you got me in living here longer. 95...as far as I can remember, we've always had 10%. Could be wrong though.
I've seen a lot of gas changes in my time here.
Plus there's a Pancho's in town.
