Adding Homlink to sunvisor
Old Nov 26, 2007 | 03:08 PM
6868vfco's Avatar
homelink
I just installed the visor. ordered it from ford i had the parts guy look one with homelink and gave him the right trim code . direct replacment and all that is needed for them to work is constant power and ground.
Old Nov 26, 2007 | 03:51 PM
Dog'em's Avatar
Originally Posted by Limited
Any pictures of this, I to have the sunroof and do not have the overhead console to mount to.
I would get you a photo but the wife has the camera and still at her folks for the holidays. If she gets back tonight I'll try to get a few.
I just removed the dome light and mounted it thru the headliner just ahead of the light. I had to take a rasp and file down some of the thickness but it works great and looks OEM.
Old Nov 28, 2007 | 08:52 AM
Limited's Avatar
Any luck getting pictures? Did you just remove the light assembly and work through the hole or did you have to take down a portion of the headliner?
Old Nov 28, 2007 | 08:59 PM
StickyF250's Avatar
Does the button faceplate separate from the main body???
How did you all install?? Cut a hole and slide it in, or pull apart and snap back together once it's installed??
Old Nov 28, 2007 | 09:41 PM
lastdeadlast's Avatar
The button faceplate does come off yes. Once you do that I made a small template out of paper to cut through the plastic of the overhead console. I used a drill and a dremel and it worked pretty good. However once the hole was done I discovered that the catches on the faceplate couldn't snap into the homelink module because the console plastic was too thick. To solve this, I used the dremel to thin out the plastic on the back of the console, only around where the homelink would be resting. It took a few tries to get it right, but I was finally able to click the faceplate in.
Does this help?
-Shannon
Old Nov 28, 2007 | 11:02 PM
Limited's Avatar
What did that set you back ~250
Old Nov 29, 2007 | 12:48 AM
StickyF250's Avatar
Yeah that helps... Thanks!
Old Nov 29, 2007 | 12:13 PM
6868vfco's Avatar
i have one already out of the visor i think only two buttons work?
Old Nov 29, 2007 | 02:27 PM
rambunctious's Avatar
limited
you can just splice from the vanity wire ( use scotchlocks, or solder if you really want to)
Ramb
Old Nov 29, 2007 | 05:42 PM
Limited's Avatar
Originally Posted by rambunctious
limited
Ramb
Thanks, that is what I was going to do but knowing that these trucks are made on an assembly line I figured they made one wiring harness and then optioned it later so that the plug might just be tucked in there and sitting ready to be used. I can feel the cutout under the fabric where the module would be placed, so it was just a logical guess that the harness would be there two.
