2WD looking for economic posi
Old Nov 15, 2007 | 01:23 AM
xlint1's Avatar
Hi guys. I have a 2WD (actually single wheel) that I'd like to try and get better winter traction with. M+S tires with a posi traction is what I'm thinking. What is out there to keep costs down to do this? Should I try to find a boneyard rearend and steal the pumpkin guts? Or is there another set up that can be installed? I thought I saw something in Summit Racing's catalog once for this, but it was pretty expensive. Thanks.
Old Nov 15, 2007 | 02:11 AM
sandyf150's Avatar
never really looked for one for my truck since it came with one but i know that mustang ones are expensive and they are for the 8.8 rear. I would just look for a used rear like you said, just try and find one that is in good condition because the ford ones do wear out.
Old Nov 15, 2007 | 10:08 AM
05supercrew's Avatar
This is something you dont want to cut corners on, do it the right way or it could cost you twice as much.
Old Nov 15, 2007 | 10:32 AM
ThumperMX113's Avatar
Get a Detroit Tru Trac.
Since when did any 2004+ F150 come with a locker?
Old Nov 15, 2007 | 11:24 AM
Dribone's Avatar
i've got an 8.8 posi sittin in the box, new from the dealer. never put it in, and at this point i'm not planning on it. If you're lookin to buy one, email me
hawker_metalworks@yahoo.com, I wouldn't mind gettin rid of it.
Old Nov 15, 2007 | 12:12 PM
dbhost's Avatar
Detroit True Trac is really the way to go. God traction, good manners on the road. Not terribly expensive.
Old Nov 15, 2007 | 08:51 PM
warbat66's Avatar
i was looking at doing the same myself. For a detroit tru-trac the out the door total was around 800 after install.
Old Nov 15, 2007 | 09:26 PM
hwm3's Avatar
A Tru Trac isn't a locker either.
Old Nov 15, 2007 | 11:57 PM
No kidding .. Who wants a true locker/posi unit for a daily driver, though ..
Old Nov 16, 2007 | 12:02 AM
scott1981's Avatar
Add a couple hundred pounds of weight to the bed, will do a better job than a Ls will anyways. A locker of any sort would be dangerous for icy/wet conditions.
Old Nov 17, 2007 | 04:04 PM
Riken's Avatar
just get an electric locker, $500 for the 8.8, don't know if they built one for the 9.75 yet. ECTED by Auburn, do a search.
LS diffs don't work when you don't have traction. i know this sound weird but they are often misunderstood. they work great on pavement like when you're at the drag strip, but put them in the mud or snow, you will get one wheel spinning. plus most clutchpacks fail before the life of the vehicle.
Old Nov 17, 2007 | 04:08 PM
WhiteGTSofDeath's Avatar
For the 8.8 you can get the OX too. That setup is badass.
Old Nov 17, 2007 | 10:01 PM
warbat66's Avatar
ive looked for an ox locker for the 8.8in and havent had any luck. Where did you find it at?
Old Nov 17, 2007 | 10:19 PM
Riken's Avatar
isn't the ox cable operated? there are alot of options for the 8.8 since it's the same as the mustang.
Old Nov 18, 2007 | 12:39 AM
extremeethan's Avatar
I just put a stock ford limited slip in my ranger that I picked up off ebay for 120. You can go that route or like everyone says True track, in my book that would be the only choice for my f1 if my stock LS ever lets me down. As for my ranger I added extra friction plates so it is basically a locker with just enough slip to not brake axles
