Fabtech users with rear AAL -
I was wasing if the rear ubolts that come with the fabtech lift are long enough to use an add-a-leaf with? you do you have to get longer u-bolts?
Also, if you are using a front 2" spacer on your fabtech, are you using a 2 1/2" add-a-leaf? what make?
thanks
thanks
Originally Posted by Josiah
They are not big enough for a 5" block + factory 2" block stacked, FYI. I have custom made u-bolts from Autospring.
Originally Posted by ThumperMX113
What are you talking about? He never said anything about stacking the 5" Block and 2" Block stacked?
Originally Posted by purpony
thanks all- hey kick ***- does your truk sit level with the 6" , 2.5" spacer, and 2.5 AALs?
I have an extra, it came with a set of coilovers I purchased. They come in the same box, as well as a diff skid plate, impact/strut bars, some hardware. Let me know if you're interested in any of this. I was going to put it all on ebay but would hold whatever this forum needs.
Now that I think of it I don't think I ever measured the block, but I'm pretty certain it's 5". I'll go check.
Yep, 5". I have the ubolts as well.
