Dealer broke 4 spark plugs!
Originally Posted by freekyFX4
Yeah, I knew that, but I just had to play devil's advocate. Maybe the number of miles on the engine has something to do with the likelyhood of the plugs breaking.
Hey, havnt read much of this thread but i thought i would let everyone know that at 70 000km's, ford told me to change them so they would NOT be siezed... well, they tore thecab off of my truck... ripped apart the engine.... broke 7 plugs off.... broke ford's special tool they have designed to remove the broken plugs... and yeah, 3800 dollars later my truck runs the exact same as it did before! actually worse because i had to go back in twice to make them finish putting panels back in and tightening things up! it wasnt a good few days for me... and yes i have pictures of my truck in peices
The first shop was planning on pulling the motor, but they got it out without. The dealership I took it to to finish the job did it right. I wish i took it to them in the first place. Clearly, not all dealerships are created equal.
sorry 'bout you luck dude. my pain in the *** happened a couple weeks before christmas. can't wait to see my cc statement...
I just turned over 100000 and am due for a plug change.What years does this affect?Is it possible to spray something like PB Blaster on them and let it sit a while?The truck is not my daily driver so letting it sit a while to let it soak in a while is possible,if it would help.
I have a 05 gator with a little over 60k on her and attempted to change the plugs out. Followed the TSB procedure and snapped the first plug i tried. Dealer wanted $260 to extract the one. Porcelain and shield were stuck in the hole. Thought i was screwed and was going to just buy the Rotunda tools but found this instead http://www.tooltopia.com/lisle-65600.aspx. Tool is a lot cheaper then the rotunda tool and worked like a champ! So far i've changed 4 plugs and 2 have broken. It's too cold here to finish the job now.
I'm torn on what to do with my truck -- since it's not likely to accumulate more than 30,000 to 40,000 miles in my lifetime, I'm leaning toward doing nothing with the plugs and letting my son (or whoever owns the truck after me) worry about it......
If your truck is NOT at 100K and you are not having driving issues then don't worry about changing them. People here freak out about these plugs and want to swap them out before their time. I have seen very few problems from the plugs themselves. They are actuallya good design as far as functionality is concerned. Leave them alone unless they are broke or past there projected usage.
Yikes! Preventative maitenance is the way to go!.....
I got nervous and had my plugs done at 65,500. They all came out fine and I was told they would have come out fine with 20,000 to 30,000 additional miles. The new plugs performed no better than the ones removed. Same mpg, etc. All I got was piece of mind. I plan on going to about 90,000 on this set. I do think it is very important to use a gasoline with a good detergent.
If you want to throw the money at it for peace of mind then go ahead, but everyone here is under the impression that the plugs MUST be replaced as soon as possible. When that is not the case.
These plugs are obviously a different design and style and people have to change there thinking on how to mainntain them.
Your Theory suggests that there is a problem with the plugs. THERE IS NOT!!! THe problem is with removing the plugs. If you will never reach the recommended replacement time and you have no drivablity issues, WHY WOULD YOU REPLACE THEM?
