Straight Pipes
Straight Pipes
Originally Posted by supachargd2k5
nice, how does it sound?
Originally Posted by JBMX928
who cares what it looks like unless its actually visible from the back or side?
its about how it sounds
Judging by all the crush bends I can count, you have approx 60 feet of effective pipe length.... so on a cost per virtual foot basis, ya gots a real Bargoon! LOL!
Ya know what? In keeping with yer general Redneck theme, you could simply have bought a roll of flex pipe and run 'em any which way yerself
MGD
Originally Posted by MGDfan
Well, I hope so ... because it sure ISN'T about how they perform!
MGD
MGD
Originally Posted by PimpRohr
Poor Truck...
Originally Posted by Dribone
60'?!?!?! how is that calculated?
A 90 = 10 feet of straight @ equivalent diameter
Assign a fraction of that to a simple crush, X the # of crushes = a conservative estimate. It's likely even more, lol.
Fun with numbers.
I can't believe you guys still take ol' bubba seriously!
Originally Posted by Exhaust_Guru
"THE EXHAUST PIPE
To save costs, your typical stock exhaust uses small diameter, crush bent pipe. Crush bends are easy to make in mass production. However, crush bends can reduce the flow of a pipe by up to 50 percent. Your typical exhaust system made by the local neighborhood muffler shop is also crush bent. The best exhaust systems, like most pre-made exhaust systems, come with mandrel bends.
Mandrel bending is done by a special machine that uses a non-crushable insert, or mandrel, that goes into the pipe while bending to prevent it from being crushed. If you are making your own exhaust, you can buy pre-made mandrel bends from MagnaFlow, Burns Stainless, Kinsler or Bassini. The huge speed parts mail order emporium Summit Racing stocks both the right kinds of mufflers and mandrel bends.
It is better to use a smaller diameter mandrel bent pipe than a larger crush bent pipe. Remember that maintaining velocity is just as important as reducing backpressure."
