who's hauled the most
2700lbs of Lava Rock and Bricks....without breaking a sweat
http://i62.photobucket.com/albums/h1...g?t=1174863665
I have towed my uncles bobcat skid steer loader the only way i knew it was behind me was that the surge brakes were wore out so the tonge of the trailer kept jerking. i have the 4.6 and a lot of hills to drive over.
Originally Posted by CANES676400
you havent seen those ford commercials where they use the F-150 to stop a cargo plane on the runway
http://www.pickuptruck.com/html/news...150/cargo.html
50+ paver stones, + 2 yards of wet clay dirt, not quite mud. The axle was less than 1/4" from the bump stops. It handled the load, but it was NOT happy...
I figure I had probably about 4K lbs in there.
with the suspension set up and all, i got tired of hauling the trailer with the welding equipment, and every weekend 5000 pounds or so of steel... got me one of these
6000 # deck capacity and better mileage than the pickup (average of 18 loaded)
Dont know how much weight this was but I did have my truck loaded down pretty good..
16 sheets for 3/4" plywood
24 sheets of 1/2" plywood
40+ 8' 2x4's
10 10' 2x6's
There was a few other things also but cant remember...
pulled the weight fine but the ride was harder then normal.
40+ 8' 2x4's
10 10' 2x6's
~2500 pounds of dirt/sod. i dont think a supercab is rated to haul this much, i went over a speed bump and all the weight pushed down on the springs and my left tailpipe bashed against the rear differential, denting the pipe. now i need to get it fixed because it is probably disrupting exhaust flow.
look how low its saggin
