**My Truck Died On Me (NEED HELP)**
Old Oct 21, 2007 | 11:12 PM
FX4REACTION1's Avatar
I was driving down the street, and got on her kinda hard to get out of the way of traffic, And she bogged down really bad, then when I went to give her gas again she died! And now she'll start, and idle but as soon as i give it some gas she dies
Checked the edge and got the following codes......
(P0171) System to lean Bank 1
(P0174) System to lean Bank 2
(P1000) On-Board Diagnostic (OBD) System Readiness - Test not Complete
I'm afraid it has to do with my plugs I haven't changed them (80,000 Miles) And I know that I've used bad gas before......
What is it?
Old Oct 21, 2007 | 11:36 PM
TonkaTruck33's Avatar
my dads fx4 is still doing the same thing.. since the last time u posted about problems. tell me how things go.
Old Oct 21, 2007 | 11:40 PM
IzInBloOm's Avatar
the P1000 is nothing. It just comes up when all the OBDII diagnostics haven't run.
I would guess it's some kind of fuel line issue. Since it appears in both banks I would guess it isn't a single injector. Most likely not the fuel pump since there are other OBDII diagnostics for that.
When is the last time you changed the fuel filter?
-ii
Old Oct 21, 2007 | 11:45 PM
Quintin's Avatar
Unplug the MAF and try again.
There's also a vacuum hose on the driver's side rear of the engine that connects to the bottom of the intake manifold. On high mileage trucks, this hose sometimes gets soft and pops off. It also feeds your brake booster, so if you don't have power brakes, there's your problem.
Old Oct 22, 2007 | 06:12 AM
Finally started her up, she ran like s**t for about 5 min. then started running fine. But is still throwing the same three codes, at every startup. As for the fuel filter, just changed it two weeks ago. And quintin, I do have power brakes they never stopped working even when the truck turned off.
I think my injectors are shooting out to much fuel. It's giving all the signs of a flooded engine, could it be that?
Old Oct 22, 2007 | 07:21 AM
1sweetsvt's Avatar
not if it threw lean codes.....change your plugs and see what happens
Old Oct 22, 2007 | 07:34 AM
MGDfan's Avatar
What is it?
I've said it before - a little searching does not hurt; this has been reported many many times ( just plug the codes into the search engine) - read this one over completely:
https://www.f150online.com/forums/sh...ighlight=p0171
- and then try cleaning the MAF after you have ruled out the possibility of a vacuum leak.
It's unlikely it's your plugs - although they are indeed overdue for a change...
Good luck
Old Oct 22, 2007 | 01:43 PM
Rockpick's Avatar
Moderator &
Sounds injector'ish to me, too. Not that I know jack-diddly-do about it!
Best of luck, bud.
Old Oct 22, 2007 | 01:55 PM
i.ride.suzuki's Avatar
Where is MGD to say....
"80,000 miles?! Have you replaced your o2 sensors?"
Old Oct 22, 2007 | 02:27 PM
MGDfan's Avatar
That's what I have you for !
Three cylinders and a stuck open exhaust valve, remember? I need all the help I can get right now ...
Old Oct 22, 2007 | 08:07 PM
Quintin's Avatar
Injectors cause rich codes and they usually bring a misfire code or three with them.
Old Oct 22, 2007 | 08:32 PM
MGDfan's Avatar
Well, OP - what did you find?
It's usually courteous & helps other folks later if the resolution gets posted, so cough it up!
MGD
Old Oct 22, 2007 | 09:59 PM
ThumperMX113's Avatar
I'll throw in my late 2 cents. MAF or Injectors.
Old Oct 22, 2007 | 11:04 PM
x2
Old Oct 22, 2007 | 11:16 PM
While we are at it... I'll say he installed the fuel filter backwards and his fuel pump is going out!
