Anybody with a 2007+ with either the S&B or Outlaw intake?
Old Oct 19, 2007 | 04:33 PM
hmfic's Avatar
I currently have a Outlaw intake. Ever since I bought it I have been dealing with this annoying creaking that occurs at slower speeds and even idle. It turns out it is coming from the contact between the rubber throttle body elbow and the silver firewall insulation behind the throttle body. Looking at other pics of peoples engine compartment makes me think the insulation was new for 07.. Am I correct on this?
I am wondering if there is anyone with a 2007 and the Outlaw intake have this same problem? I am seriously considering the S&B as the repalcement, but want to hear from others with a 2007 before having the same problem again.
Old Oct 22, 2007 | 12:36 AM
hmfic's Avatar
ttt
Old Oct 22, 2007 | 12:39 AM
FX4life's Avatar
Im not an 07+ but I have the S&B and have absolutely no problems at all, I love it to death, check my gallery if you want some more pics!
Old Oct 22, 2007 | 12:41 AM
FX4life's Avatar
*EDIT* sorry, I think the silver insulation is new, all I have is a black fiber type insulation in mine, does yours not have that?? Also is part of your problem the drone of the engine lugging?
Old Oct 22, 2007 | 01:03 AM
hmfic's Avatar
Does your black insulation touch the elbow on the S&B? My silver insulation is actually compressing my rubber elbow.
The drone is not the problem, it is definitly a creaking of some sort.
Old Oct 22, 2007 | 08:35 AM
ThumperMX113's Avatar
I have the silver lining and I don't have any noise from my S&B.
Old Oct 22, 2007 | 10:44 AM
FX4life's Avatar
Not that Im aware of!
Old Oct 22, 2007 | 01:31 PM
hmfic's Avatar
It does look like your s&b sits a lot lower than the Outlaw. Might be a better fit with the Silver insulation. Thump's setup sounds like it works.
Old Oct 22, 2007 | 11:32 PM
Jersey1035's Avatar
Could you shorten the elbow where it fits onto the throttle body? Have you contacted Outlaw? I would let them know, they may be able to come up with a fix.
Dave
Old Oct 23, 2007 | 01:05 AM
hmfic's Avatar
Dave
Yes, I emailed them right when I discovered what the problem is. Their respose was that they have never heard of this happening. They confirmed that I had it on correct as well. I'm guessing they never tested it on a newer truck with this type of firewall insulation. If you look close at the pic, it is pushing in low on the elbow, so i'd have to cut it down quite a bit, then I'm not sure if everything else would fit like it should. It might be worth a try though. I just don't want to cut it up, just in case I end up selling it. I shouldn't have to cut it to make it fit.
Old Oct 23, 2007 | 02:45 AM
2007FX4's Avatar
I have an 07 and also have the insulation. My S&B intake does rub against the insulation.
While driving the truck I dont hear any weird noises at all. But if I grab the air box and jiggle it the coupler between the air box and the fender squeks pretty bad.
Old Oct 23, 2007 | 04:01 AM
hmfic's Avatar
First off, welcome to the site.
Good to know. You don't hear anything while in the cab coming though the firewall from the rubbing.? Mine is very noticeable at idle or while driving slow such as backing out of the driveway.
Old Oct 23, 2007 | 04:53 AM
2007FX4's Avatar
nope I dont hear any strange sounds from it at all
Old Oct 23, 2007 | 06:53 AM
svt2205's Avatar
FWIW, I've found that email is not the best route for dealing with a part or product issue with most manufacturer's. Call and talk to them. I did this with S&B when one of their distributors shiped me a CAI with missing and defective parts. The distributor didn't do crap to fix things, one call to S&B and I got new parts. Tell them you want a replacement for the part that's possibly rubbing. Worth a try.
If you buy a S&B, pay careful attention to the intake tube where the mass flow sensor mounts. They don't have their molding process well controlled. There's a height issue, that can allow the sensors sealing gasket not to seal. A little reworking, can fix this.
