Thinking about 37's, Have some questions first.
I am well considering going with a little more lift and getting some 20's and 37's. I have a couple questions first though.
#1. What is the cheapest way I could lift my truck a little more to clear the 37's? Right now I have a 2" level and a 3" bodylift with 35's and no rub what so ever. I compared it to a truck with a procomp 6" lift and it only sat 1" higher in the rear.
#2. I have 3 73 gears, will this be enough for the 37's? With the 35's right now it has plenty of power. I can even powerbrake the truck.
#3. If I didnt regear what would be the result? Mpg, Power...etc?
Thanks for all of the help in advance!
37's are a big tire, I had them on my dodge and they killed the fuel mileage (even on my diesel) truck. It's not so much the height as it is the actualy weight difference.
I think you would need at least a 6" kit to go with your Body lift. So many of the 20's out there in the 6x135mm bolt pattern are a negative offset and stick the tires out a good ways from the fender, that being said, it takes a lot more lift to clear them.
Gears will be a must to keep the things from burning a gallon of fuel from stoplight to stoplight.
check out incubus alloys for your wheels, lots of different styles and they look very aggresive with the toyo MT's. Check out my gallery I have the brawns with some 37 toyo MT's
Toyo's are my pick too when I get the lift...when.. lol
