ATF. Time for a change.
Old Oct 7, 2007 | 03:37 PM
SVTErick's Avatar
Is changing the ATF as easy on this transmission as it was on with 4R70W? I used to just drop the pan, change the filter and fill it back up. Anything different? Do you still re-use the gasket. Any other drain points I should know about? I want to use Royal Purple ATF on this truck. Any recommendations, tips, etc... Thanks!
I forgot to mention I have a 2004 4.6 F150 with auto transmission and 38,000 miles.
Old Oct 7, 2007 | 03:42 PM
MGDfan's Avatar
Just say NO to Royal Purple....
--> https://www.f150online.com/forums/sh...t=royal+purple
Old Oct 7, 2007 | 03:52 PM
SVTErick's Avatar
Thats a good read and some good information on labeling. Thanks. I used Mercon V on my 2001 truck when I did the change. I dont see any purpose in spending the extra money on RP. Its still way expensive!
Old Oct 7, 2007 | 06:45 PM
flanaganman's Avatar
just droping the pan off will not get all the old tf out change the filter while its off.
http://videos.streetfire.net/video/6...b1003618c0.htm
Old Oct 7, 2007 | 06:57 PM
SVT Pilot's Avatar
The dealer just did mine with Mercon V. Just changing the pan fluid will leave the older crud in the lines, defeating the whole purpose. Better just to get it flushed and be done with it for a couple years.
Old Oct 7, 2007 | 08:23 PM
SVTErick's Avatar
How do I go about flushing it, and how are you so sure the dealer REALLY did all that?
Old Oct 7, 2007 | 10:20 PM
Tbird69's Avatar
How can you be sure the tranny shop of choice is doing all that? Sometimes you just have to trust that things are getting done. Flushing the transmission isn't something you can do yourself, you need special equipment to do it properly.
Old Oct 8, 2007 | 06:01 PM
gregerm's Avatar
any little mechanic shop can flush the tranny. Some oil change shops have the equipment. I recomend just getting it flushed the first time and second pull the pan and change the filters. dropping the pan only drains about 4 quarts. Your torque converter holds alot more.
Old Oct 8, 2007 | 06:44 PM
ONE04FX4's Avatar
Talking
actually on that chart it gives reference to mercon v on it. i am using royal purple in all capacties in my truck and have been for two years with no problems.
Old Oct 8, 2007 | 07:31 PM
countyboy04's Avatar
Isn't there a drain plug in the torque convertor as well? At least there was one on my '93 f150.
Old Oct 8, 2007 | 08:25 PM
MGDfan's Avatar
ok - original post was in April - they finally updated the chart - about time
Old Oct 8, 2007 | 08:55 PM
ONE04FX4's Avatar
Talking
i agree on that. they are a small company as well.
Old Oct 8, 2007 | 09:27 PM
ThumperMX113's Avatar
LOL Poor RP got a bad wrap all because of you MGDFan!
