Crummy Motorcraft Oil Filters!
our filter is the fl820s, not fl400 or maybe im wrong, next time buy an fl820s from walmart, then take it to Napa, and they have a metal filter wrench that attaches to a ratchet, it fits so tight you may have to clean off the end of the filter to get the filter wrench on, its not a few teeth that bite on the filter, its every teeth gets gripped... ive done the punch a hole thing, live and learn with the adjustable filter wrenchs and then just buy the specific one, actually the napa "strap" filter wrench is ok, it has no rubber on the inside strap but somehow grips better
Originally Posted by madcat6183
Yea this happened when I let Monroe change my oil before a long trip last summer due to lack of time. That was the LAST time I ever let anyone do that.
Not to vere off subject but motorcraft filters have been proven to be better filters than almost all of the Premium and big name filters, including the big name ones that try to cash in on their other product lines such as K&N.
Tip for oil changes, take a punch and pop a hole in the bottom of the filter and let it drain prior to trying to removing the filter makes it ALOT less messy. As for filter wrenches I always found the strap wrenches are easier to use than the ones that have claws and the ones that fit on a wratchet.
The filter box says the gasket is pre-lubed, but i always run a bead of new oil on the gasket to make it easier to take off. Also when you put it on, spin it on by hand (quickly) when it stops free spinning, turn it .5- 1 full turn and it is pleanty tight.
I have a really nice wrench i bought at walmart that is kinda like a pipe cutting tool, its a slip band that goes around the filter, and the harder you pull on it, the tighter it grips the filter too. Works great on our larger diameter filters, where the "socket cups" tend to fail
(btw - once you thread the new filter on, pull the drain plug one more time and you'll get a little more of the old oil out...)
oh... and I have much better luck turning it counter-clockwise to remove it...
