Who can hook me up with a fix....
I've seen cars/trucks/suvs/motorcycles blow up or catch on fire because the nutcase left the engine running. Infact, the gas station right down my road had a car catch on fire because of this like 3 months ago... and they had their two daughters inside... suffice to say they both died because of the father's stupidity.
So you could be the next victim. I think there are like 500 of these fires a day all across America...
The only real harm from leaving the engine running while fueling up is that the fuel gauge may not respond properly for a few miles.
Back to the window thing, yeah, the regulator's broke. There ain't nothing to replacing it, fortunately everything bolts in so you won't have to drill out any rivets like on the older trucks. My driver's side did it about a year ago in 17 degree weather, pissed me off.
I'm sure glad I got my truck and you got yours. Of coruse, it probably wouldn't have happened if you would just paint the spokes black!
Well, I can't certainly say you've lost your memory with age.
Originally Posted by Stealth
June 6, 2005.
I got mine March 19, 2005. It was built 11/17/04 and delievered to Hilliard Ford. I was a little concerned since it sat on the lots so long.
Window Assembly Diagram
http://www.fileden.com/files/2006/10...win%20assy.pdf
My driver side window went down for the count this past weekend. I'd heard it 'scraping' a bit in the past few months. You can tell it just didn't sound right. Anyway, I didn't have time to sit around and wait to have a part delivered from an online source. I figured I'd take my lumps and just have the dealership do the job for about $200. Wrong ... $321!!!
BTW, I've always liked your truck!
Originally Posted by PawPaw
Hot catalytic converter's around gasoline fumes can cause problem's. Also watch out for anything that may cause static electricity around the pump's when fueling.
No problems with the fuel level after a fill up for me.
The key ON fueling mode (approximately 90 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The transmission is in PARK (P) (automatic transmissions), or the parking brake is applied (manual transmissions).
The key is in the RUN position.
At least 15% of the vehicle's fuel capacity must be added to the fuel tank.
In key ON fueling mode, a 30-second timer activates after the transmission is put into the PARK (P) position or when the parking brake is applied. When the 30 second time has elapsed and at least 15% of the vehicle's fuel capacity has been added, the fuel gauge response time is 90 seconds to read from empty (E) to full (F). When the transmission is shifted out of PARK (P) or the parking brake is released, the fuel gauge strategy reverts to the anti-slosh mode. This mode prevents slow to read full events from happening if the customer refuels the vehicle with the key in the RUN position.
