7pin and 4pin trailer connection issues
Old Aug 25, 2007 | 06:44 PM
Voodoochild's Avatar
Ok..... no matter which one I use 7pin or 4pin, the right brake and turn signal do not work. Checked on 3 different trailers.
Where do I need to look, Other than tracing the cable back to the harness. I would think that it would be upstream from the trailer harness since the problem is the same with both the 7 and 4 pin connector.
Running lights work..
Old Aug 25, 2007 | 07:40 PM
GotBeer's Avatar
Check your fuses. If my batteries on my trailer are dead, when I plug in the 7 pin the charge line causes a fuse to blow and I loose my trailer brake lights. I think fuses are in passenger kick panel.
Old Aug 25, 2007 | 08:46 PM
03graylightning's Avatar
Most likely a fuse. The right brake and right turn use the same fuse.
Old Aug 25, 2007 | 09:59 PM
GotBeer & 03graylightning
You guys nailed it. Fuse #36 10amp Trailer brake right side and turn signal.
Thanks I now can safely make right turns with a trailer....
