Spark plug change @ 90K+ Miles please help
Hi!
I need all the advice you F150 can bring me. I have a 5.4 3v with 90K+ and i plan to do the spark plugs change.
In order to maximise the posibilities to make the change sucesfully I plan to follow these steps:
1. Run a 1/2 pint through carburetor or throttle body throat injecteing slowly SEA FOAM through direct manifold vacuum line of brake booster.
2. Loose 1/4 tourn each spark plug and apply Aerokroil (how much aerokroil can apply without hydro-look risk?)
3. After sit one hour adjust again the plugs & coils and start the engine. (If I start the engine, the aerokroil is going to burn isn't?)
4. Repeat step 2 but loosing a little more if not too tight.
5. Sit overnight and repeat step 3.
6. Slowly turn the spark plug out. Some screeching and high effort may be noticed but, not in every case. The expected removal torque is about 33 lb-ft (45 N-m) but should decrease on the way out. If it is higher, try turning the spark plug back in a half turn, then back out again. If the turning torque still seems high, repeat the back and forth rotation along with some penetrating oil to reduce turning effort.
7. If I feel it's to tight (reach the 45 N-m) repeat steps 3 & 4.
Is this a good idea? are ther some fellows with more than 90K+ miles changing the spark plugs sucesfully? How they do it?
Just my opinion since I haven't touched the plugs in my truck yet (only 21k), but 33 ft lbs doesn't sound like enough to unseat a plug that has been in there for 90k miles. Maybe a good guideline not to exceed once you've cracked them loose though.
Here's my directions.
1. let the engine run until it's hot.
2. working as fast as possible get the coils off and only break the plugs loose 1/8 of a turn.
3. spray the Kroil until it's to the top of the nut on the spark plugs.
4. let it sit over night if possible.
5. work the plugs back and forth like trying to get a rusty bolt out.
6. PRAY.
6. PRAY.
6. PRAY.
6. PRAY.
You want the engine warm, let it sit 1-2 hours after driving, this way those aluminum heads aren't tight on the plugs and the spray will do some good.
Tell me how many of these spark plugs you both have taken out?
My self, I lost count.
And if it's too hot wear gloves.
Originally Posted by SVT Pilot
I'm all for DIY whenever possible but in this case wouldn't it be better just to take it to the dealer? That way it would be on them if any plug(s) snapped.
Originally Posted by Tbird69
Relax, don't take it so personally. I'm just giving some advice to people that haven't done this before, so they can avoid any potential problems--such as personal injury.
All I was asking is how many of these trucks have you done?
Of course I could be lying about my experience too, but I'm not.
6. PRAY.
6. PRAY.
The plug breakage issue appears to be primarily caused by insufficient gap between the snout of the plugs, and the walls of the head. The Seafoam is IMPORTANT. I figure on changing mine at around the 80K mark, or the last month I have the extended warranty, which will more likely be the case, About 5K before then, I am going to start running fuel system cleaner (Seafoam or the like) through the engine every two tanks full... That should do the trick I would think!
