Has anyone replaced their fuel pump?
I'm going to have to replace my fuel pump. My truck will barely start, when it does start it dies when I give it gas. How hard is the replacement? Has anyone done it themselves? It's going to cost me $693 parts & labor + $100 for the tow there.
Originally Posted by Ftruck05
Why do you "know" it is the fuel pump??? Mabey you have an injector stuck wide open.
You can just turn the key ON...without starting.. and the fuel pump should begin pumping. I'd say the fuel pump went Bye-Bye if it's not spraying gas out.
Two straps holding the gas tank up.. with 13mm bolts holding the straps on. Disconnect the fuel filler neck hose. 3 screws inside the door. Disconnect all hoses into the tank and Lower the tank down.
That's most of the work right there. You'll need a floor jack and some pieces of wood to hold the tank in place and lower it.
It might even be easier to unbolt the bed and have 3 of your buddies come over to take it off. Same there... unbolt filler neck and elecrical connections and lift the bed off.
Good Luck
Good Luck
Originally Posted by BestNTx
I fixed it!!! Thank god. It was the fuel system deactivation switch. Somehow it got tripped when I was doing the headlight/fog lamp mod earlier.
Where is the fuel system deactivation switch located at?
The switch is used to reset your system in case of a wreck. When you truck senses the impact it automatically shuts down your fuel system to eliminate fire in case your lines were cut or other risks.
Good call.
I had the same s#i+ happen on my 92 ranger. Took me about an hour and than after lookin under the hood I saw a sticker that tells you all about the deactivation switch. You sure would have felt stupid dropping 7 bills on something as easy as a red button. I know I would.
Good call.
