Quintin! Help to clean the injectors! Truck abused with Pemex fuel
Old Jul 1, 2007 | 10:11 AM
artgarcia's Avatar
Exclamation Quintin! Help to clean the injectors! Truck abused with Pemex fuel
Hi there! I'm in the process to change my fuel filter, as I'm in México, i don't think PEMEX use good quality detergents on their gasolines. I use Magna (87 octane) and drive the truck 90,000 miles without change the fuel filter. :o
What kind of work i need to clean the injectors?
My truck actually have the check engine light (no scaned yet) and in hiway speeds don't have power to go uphills but i can drive with easy foot at 60Mph if goes faster start to hesitate.
Thanks fro your recomendations.
Old Jul 1, 2007 | 10:31 AM
Usted puede ser que desee utilizar algo a lo largo de las líneas del limpiador o de SeaFoam de la inyección del combustible de STP. He tenido siempre buena suerte con esa materia. Su mejor apuesta está con Seafoam.
Old Jul 1, 2007 | 11:05 AM
artgarcia's Avatar
Gracias por tu respuesta! Si ese es el producto que me habían recomendado aquí, pero no lo enconté en el buscador (no me acordaba de el nombre del producto) Muchas gracias por la respuesta en español, está perfecta!
Thanks fopr your answer! This is the product recomended here I did not found in the search ( i did not remember the name of the product) Thankyou very much for your spanish answer, it's perfect!
Old Jul 1, 2007 | 11:07 AM
artgarcia's Avatar
Quintin what is your opinion about Seafoam?
Old Jul 1, 2007 | 11:59 AM
artgarcia's Avatar
Made gas filter change after 90,000 miles
I just made the gas filter change this is what i found
I want to make the best do it myself injector clean task, please help.
Old Jul 1, 2007 | 12:26 PM
Tuff4rd's Avatar
No mames Try this, it may help you.
http://www.chevron.com/products/prod...of_3step.shtml
Old Jul 1, 2007 | 12:30 PM
Ilovemyford's Avatar
Artgarcia, you need to change your filter every 15000 miles. I would even change it every 7500 miles, if the gas you re getting in not up to standard.
Old Jul 1, 2007 | 01:49 PM
artgarcia's Avatar
Yes! i know i abused but my atempts for remove the filter did't work. Now after more research i just change the filter with a little more patience. I'll evaluate this product, do you have some experience about? How is this used? Thnaks for your input.
Old Jul 1, 2007 | 01:52 PM
artgarcia's Avatar
Yes I know i was negligent about. Now i know hot to change it and I'll make the task every 2 oil changes (12,500 miles) I don;t know why the dealer charge so much and wally world don;t make this easy task. It takes less time than a ordinary oil change!
Old Jul 1, 2007 | 01:57 PM
Quintin's Avatar
I dunno about Seafoam. Most aggressive stuff I know of you can dump in the tank is either BG 44K or Chevron Techron concentrate.
Old Jul 1, 2007 | 04:44 PM
Looks familiar. Check my gallery.
Old Jul 1, 2007 | 07:09 PM
kd4crs's Avatar
BG 44k is what alot of the shops in my area use. It works better if you run it through a high pressure injector cleaning machine but you can also dump in in the tank and run it through with fuel.
Old Jul 2, 2007 | 01:14 PM
artgarcia's Avatar
Never Hear of BG 44K Maybe a more shop stuff than consumer? I'll try to get one of them. Thanks for your input!
Old Jul 4, 2007 | 12:30 AM
artgarcia's Avatar
Thanks for your sugestion I'll trow a bottle in my thank and check what hapen.
