Hella Tailights
Originally Posted by Adam06FX4
how about the turn signals? there not fast are they?
Gawd, I hope not - Like Krazy_Kanuck, mine are from Tire Rack too
Originally Posted by Black3v
I have a Recon LED 3rd brake light and it works fine on my '07. It is possible to get 2 bum lights in a row since they are coming from the same place and were probably shipped to them in the same shipment.
Got mine today from the Tire Rack, they popped right in, no cutting of metal supports as f-150Duke had to do and no problems with the third brake light lighting up with hazard lights and headlights on. In all everything worked perfect,the hardest part was putting in the new fuse under the dash.
Not to sure why f150duke would have to modify anything as they all just slide right in easily!
krazy i think duke rewired his to have the led brake light only glow like the lower bars then get brighter when brake applyed.
krazy mine 3rd brake light was not working at first...so i tried and plugged it in again...it would not work if i pushed it in all the way until it bottomed out, but if you push it in until it hits the first click it worked as it should
Thanks for helping out, as it is rather frustrating trying to figure it out.
Trev
until it hits first click/secure...by pushing all the way in which i would think would be like most bulb connections it would not work...pulled it out about 16th of inch from all the way in until its in and secure and worked like a champ
Whats the new fuse for?
Beats me? It replaces a 20 amp fuse with a 7.5 so I guess it lowers the amount of current needed to break it (fuse) or lowers the amount of current going to the new lights, maybe someone esle can help me with a better answer.
Well, Actually.....
Just to chime in, as I'm an electrical expert, the 7.5 amp fuse doesn't lower or limit the current going to the replacement Hella LED tail-lamps, as all a fuse can do is blow when it's rated blow amperage is reached.
Since the LED tail-lamps need much less current to do the same job as the bulb based tail-lamps that they replace, the lower fuse, (7.5 vs the stock 20 amp) just protects the circuit and LED's, as they should never draw as much current as the stock bulb based tail-lamps did. It's a smart thing for Hella to do, as it shows they are trying to protect their product for their consumers.
JSB
JSB
JSB
JSB
