How to replace rear axle seals and bearings in your 04+ F150 (lots of pics)
Old Mar 21, 2009 | 04:45 PM
  #76
martinten's Avatar
This is a GREAT post. My right seal was leaking and I've saved ourselves $500 by doing it on my own. I'm no mechanic, but by following the instructions and pictures, was able to finish it in about 5 hours.
Thanks again!!!!!
Old Mar 23, 2009 | 07:27 PM
  #77
rocky57's Avatar
Very nice how to post.
Old Jul 11, 2009 | 06:37 PM
  #78
03SonicBlue3817's Avatar
Originally Posted by whaler417
I had mine done at 38K. My right seal was leaking. Is this a common problem? Seems a little early at such a low millage?
I have about 45k on mine and the left is leaking. The e-brake actuator cam arrangment had stuck on mine and caused the e-brakes to fail to release completely. I suspect the heat from the e-brake caused the seal failure. I think the e-brake problem is fairly common whether due to rusty cables or a rusty cam assembly.
Excellent write-up, Quintin.
It will be useful when I decide to replace mine.
Thanks, Mike
Old Jul 12, 2009 | 11:49 AM
  #79
Quintin's Avatar
I'm glad this has been able to help some folks out.
Old Jul 12, 2009 | 03:00 PM
  #80
87fiveoh254's Avatar
I hope I don't have to do this, but at least I know the information is here. That friction modifier smell is death.
Old Oct 14, 2009 | 11:56 PM
  #81
telovell's Avatar
I realize I'm responding late to this party, but great job Quintin! I'm getting ready to perform this task this weekend and decided to Google "F150 + replace rear bearing" and this post emerged. I was planning on purchasing a Chilton's or Haynes repair manual, but not needed now!
If anyone has a good how-to link on replacing the front bearings, please post it up.
Thanks again Quintin you rock!
Old Oct 15, 2009 | 10:15 PM
  #82
If your truck is 04+ you will have to replace the whole rotor if you want to replace the bearings.
Old Oct 16, 2009 | 07:45 AM
  #83
There is a 2 piece hub/rotor setup available for the 04-08 2wd F150 now.
https://www.f150online.com/forums/20...placement.html
Old Oct 16, 2009 | 07:36 PM
  #84
That's awesome!
Old Oct 24, 2009 | 02:20 PM
  #85
subcooled's Avatar
Just replaced my rear axle seals on my '05 79K, thanks for the great write up!
Old Nov 9, 2009 | 11:22 AM
  #86
Boid's Avatar
This post saved my bacon this weekend. Thanks!
What started as a simple e-brake adjustment turned into a passenger-side axle seal replacement. I've never been inside the pumpkin before, but with the great pics and instructions here it was a piece of cake.
I only got 2-1/4 qts of oil (still a relatively clean amber color) out of my diff, so it's probably been leaking for a while. Could the low oil explain an intermittent ABS indication on the dash? It seems to come on under acceleration from a stop. Maybe two or three times a week it happens.
I really need to have a talk with the tire shop that replaced all my rubber THREE WEEKS AGO. Did they somehow miss that the right rear rim and brakes were coated in oil? I probably would have forked over the $300 or whatever to have them fix it, too. Morans.
for Quintin!
Old Nov 14, 2009 | 03:16 PM
  #87
DirtySCREW's Avatar
Can someone confirm that its possible for the Axle BEARINGS to be bad but NOT have an Axle Leak?? I have that roaring sound that was mentioned...but i don't have a leak---DirtySCREW
Old Nov 15, 2009 | 12:36 PM
  #88
subcooled's Avatar
I don't see any reason why an axle bearing couldn't fail seperatly from an axle seal leak condition.
Old Dec 27, 2009 | 01:48 PM
  #89
burnettx's Avatar
Quintin
I have a roar in the rear end and grease all over the passenger side tire and brakes. I came in to look up what it might be and found this. Thanks, i am going to attack it next weekend.
Old Dec 31, 2009 | 07:53 AM
  #90
PlainRedTruck's Avatar
Great detail, i need a similar how to for my wifes 05 Explorer front wheel bearing/hub!! anyone have anything. Thanks
