plugs and wires
Originally Posted by sdsukid
its an 05 f150 lariat 4x4 5.4 v8...so if not wires then any other options...?
Do a search. Make sure you have the correct tools and some penetrating oil
Originally Posted by 05RedFX4
these engines no longer have plug wires, they have coil on plug ignition.
Originally Posted by i.ride.suzuki
Technically it is coil near plug. If it was coil on plug we wouldn't have these... (which are a nice upgrade over the stock 'springs' that connect the coil to the plug)
yeah i have a k&n intake and magnaflow exhaust with the edge programmer so far, just wondering what else i can do to get a little more juice out of my engine...other than that yes the truck is stock
You can putchase the upgraded boots & solid metal plug connectors as pictured from www.rpmoutlet.com for $99.00.
READ & UNDERSTAND the Ford TSB for plug removal!
i am looking at changing my plugs and wires, does anyone have any suggestions?? also what about ignition controllers?
thanks
thanks
Visteon's Coil-On-Plug Ignition System mounts directly to the spark plug, eliminating the need for high voltage spark plug wires. When combined with Visteon's patented "Energy-On-Demand" control strategy, the ignition system can match the energy delivered by the coil to the requirements of the engine. This unique system allows a lower energy coil to be used, and through fast multiple re-striking, delivers as much as 60-65mJ of total energy to the combustion process.
Features:
Matches energy delivered by the coil to the engine requirements using a low energy coil that charges and discharges rapidly.
Flexible packaging — custom housing, connector and boot configurations for specific engine applications.
High energy delivered only when required (i.e. lower engine speeds and loads).
Coil charges and recharges much more quickly than conventional ignition systems.
Reduced electrical system load over conventional ignition systems.
Directly mounted to the spark plug to provide a robust electrical connection to the plug.
Available in a "coil-near-plug" configuration with a short high voltage lead in lieu of an integrated spark plug connector.
Reduced spark plug erosion rate for improved life.
Integrated noise suppression available.
Benefits:
Improved Exhaust Gas Recirculation tolerance.
Improved fuel economy over conventional ignition systems.
Lower emissions over conventional ignition systems.
Reduced electrical system load.
Resistant to spark plug fouling.
Reduced weight and underhood complexity.
Designed for 10-yr/150,000 mile (240,000 km) durability.
Improved combustion stability at idle speeds.
Improved idle stability.
Laminations encapsulated in epoxy for environmental protection and increased safety.
