Dome & Map Light Mod
Old May 30, 2007 | 04:03 AM
codywalker's Avatar
Ordering this for map lights (above front sets) and dome (back seats)... is this correct?
- 2 VELOCITY LEDS HID WHITE HIGH POWER LED BULBS 194
http://frickinbrite.com/catalog/prod...roducts_id=141
- SUPER WHITE 8 LED DOME LIGHT BULB 212 211 212-2 214-2
http://frickinbrite.com/catalog/prod...roducts_id=110
Look good? Also, what lights do I need to replace the bed-lights on top of the back of the cab. Thanks.
Old Jun 3, 2007 | 08:16 PM
codywalker's Avatar
bump?
Old Jun 3, 2007 | 08:55 PM
LovetheTide's Avatar
Those will work.
Old Jun 3, 2007 | 09:57 PM
codywalker's Avatar
nice! Thanks a ton... and what about for the Bed-lights?
Old Jun 3, 2007 | 10:03 PM
DTheobald's Avatar
921's are for the back brake lights... check out my gallery... also here are some more pics of the leds in...
Item Name: 2 HIGH FLUX HID WHITE 9 LED LIGHT BULBS 906 921 912
quick video... alot brighter than the video...
Old Jun 3, 2007 | 11:15 PM
ThumperMX113's Avatar
DT
I just searched for the "item name" on Ebay and didn't find anything.
Old Jun 4, 2007 | 04:46 PM
K1NGoftheRanch's Avatar
i used to super bright hid 1 watt leds from v-leds in my cargo lights and they are super bright....
Old Jun 4, 2007 | 06:46 PM
Josiah's Avatar
very nice theo. What bulb is in the actual brake light up there (3rd brake light bulb). Mine went out, but the reverse lights still work.
Old Jun 6, 2007 | 12:35 AM
DTheobald's Avatar
921... almost all lights are 921 except for the license plate which is 194...
Old Jun 9, 2007 | 11:37 PM
codywalker's Avatar
my head hurts looking at these bulbs... so many different options and ****. I wish someone would say "these are perfect for dome/map/cargo" and link me to a page.. apparently this list means something...
http://www.superbrightleds.com/bulb_cross.htm
Old Jun 9, 2007 | 11:55 PM
DTheobald's Avatar
921 bulb fits you map lights, and third brake lights...
I used a 42mm feston bulb for my dome light,
and 194 fits your license plate and your front side reflectors...
once you have the size, you can pick whatever brightness you want..
Hope this helps
Old Jun 10, 2007 | 12:00 AM
codywalker's Avatar
Hope this helps
yea it does kinda.. but there are SOOO many options for each thing. Do I want 6, 9's, 12's, or "super-brights"
Look at this site just at the 921's... so many options
http://www.superbrightleds.com/mini-wedge.html
Old Jun 10, 2007 | 12:07 AM
DTheobald's Avatar
these ones
"921-x9 Wedge Base LED bulb"
921 Type with 9 LEDs, replaces 194/168 wedge base car bulbs
Available in White, Blue, Green, Red and Amber LED
measures 1.25 inch long by 0.60 inch diameter
$ 1.95
Old Oct 12, 2007 | 01:26 PM
pmason718's Avatar
[QUOTE=DTheobald]these ones
$ 1.95[/QUOTE
ok so Im going to order a (pair) of 921's for my third brake light a pair of 194's for my licese plates. What do I need for my map and dome. I have a 07 FX2 Screw if it helps to know. Also what happens to the little housing that surrounds my factory license plate bulb.
Old Oct 12, 2007 | 01:39 PM
DTheobald's Avatar
[QUOTE=pmason718]
these ones
$ 1.95[/QUOTE
What should I use for my license plate (as far as the # goes),
The white lights on the side of my 3rd brake light
and the 4 interior lights on the ceiling of my 07.
Also what is the difference b/t the Dome and the Map ligts. I take it that the map is in the front of the truck and the dome is in the rear
license plate 194
dome is festoon 42mm
and map lights and top brake lights are 921
yes dome rear, map front
