Night PICS w/ mood lights, HIDs, LEDs, and other random stuff...
Originally Posted by ford2004F150
Originally Posted by patshea098
Is it possible to just pop open the housing of the headlights and paint it black??
The Hella reflectors physically different than the stock ones... this helps with the cut off line too.
As far as the under dash kit I wanted an independent kit from the underbody lights. Here is the kit I went with: http://www.ledunderbody.com/index.as...PROD&ProdID=36
Those vents look sweet!! Heres what i've done..
Do you have any glare off your windows? I seem to have some glare off my drivers side window while driving. The grille looks much sicker in person!! I think im going to get the wheel well kits for summer.
Thanks, nice work too. I love the red truck!
No glare with the vents, they are all good.
I do get some glare, ONLY with the floor lights on some colors.
But I don't run them all the time or the windows are down.
It helps if you keep a cut off line with the light.
Example... I tucked mine up in the dash just above the inside edge of the bottom of the dash. Hiding the LEDs like that creates a cut off in the light. I need to redo the driver’s side on mine, but the passenger side seems to be good.
Basically, keeping the light only below the dash; no glare.
Hope that helps or makes sense...
I'll try to get better pics later tonight of how it's setup if you want?
I got my under dash kit from http://www.ledunderbody.com/
Originally Posted by Krohbar
If one were REALLY good, those LEDs would change from red to blue as the temp controls went from heat to cool..... Green when the system is off.
But that is SWEET....
Agreed...
I'll consult w/ engineering in the a.m. to see what we can come up with.
http://cgi.ebay.com/ebaymotors/H4-H1...spagenameZWDVW
just wanna confirm that these are the ones you bought?? and in 6000K?
