Who got an alignment after their leveling kit install and who didn't? Post results.
I installed a 2.5" leveling kit and some BFG 305/65R18's on my truck about 6000 miles ago and never got the front end aligned. Yesterday I rotated the tires and noticed some excessive wear on the outer tread of the front tires.
I realize that I should have had a front end alignment done after the leveling kit install because of the positive camber it introduces to the front suspension.
My question is for the people that did have an alignment done after they installed their leveling kit. How are your guys front tires wearing?
I just ordered a 2007 to replace my 2004 F-150 and I'm not sure I want to install the leveling kit on my new truck when it arrives. I love the way the truck looks... there's no arguing there, it looks awesome. I just don't want to continue to have tire wear problems on my new truck. I believe the tire wear issues could be resolved with an alignment, but I also have some other concerns about the leveling kits.
The SLA (short/long arm) type suspensions on these trucks has very limited suspension travel to begin with. I noticed after installing the 2.5" kit that the downward travel of the front suspension has been virtually eliminated; the front suspension is almost in full droop while the vehicle is just sitting. After installing the leveling kit I also noticed that the truck doesn't handle nearly as well as it did stock when driving over bumps and it's terrible when driving over dips in the road or potholes because the suspension can't drop any more to stay in contact with the road.
IMO = Leveling kits look awesome, but that's where the positive ends.
I got the daystar kit installed and alignment at the same time. My truck maintained the factory ride. I have noticed nothing abnormal as far as ride and tire wear. I have had the truck offroad several times with no issues. What kind of leveling kit did you install? I have been happy with mine.......
You gotta give a little to get a little I guess.
I did get the alignment after I installed the 2.5's. IMO we are spending way to much on tires these days
to even chance it. It sounds like you may have some other problems with your front end than just the level kit. Maybe a bad shock or ball joints....just say'n.
you 100% MUST align the truck after you put the leveling kit on. the caster and camber remain virtually unchanged but it throws the toe out almost 1 full degree per side which will destroy you tires with the quickness and also make the truck handle very unpredictably
I got an alignment right after I put on my leveling kit, and got another alignment after I took it off.
the tire wear you see if normal...if you don't get the front aligned.
as for there being no suspension travel, my tire goes down another 3-4 inches before it reaches the max downward travel. and I still have my full range up upward travel
You should have no change in ride quality unless your leveling kit is the type where you disassemble the coil-over and install the spacer inside the coil-over itself, not on top of the coil-over like most kits are.
Everybody except for that guy that wore out his front tires prematurely.
I got mine aligned the day after I got my AS installed, and that was also the same day that I got my new tires/wheels. 8000 miles later and I have not even rotated them yet because they are wearing so good.
I went about 800mi on the stock 18s after the 2.5" level. And It destroyed both front BFGs. But, I got the alignment before the Cepeks tho. And the handeling is so much better now. HIGLY recomend gettin' that alignment! Anything to improve her gas mileage I'm all for
Goodyear said one side (I forget which one) was way out on caster. The camber was affected, but the numbers didn't seem too far apart. I'm just happy that I did get it done for my peace of mind.
