cylinder 4&7 missfire
Old May 5, 2007 | 09:47 PM
760red150's Avatar
the check engine turned on and all kinds of codes popped up on my edge. it says "cylinder 4, 7 missfire" and some other codes too. it runs like chit. shakes like crazy. my truck is a 05 and has 77,000 miles on it. time for a tune up? i'll get the other codes and post them later.
Old May 5, 2007 | 09:51 PM
kd4crs's Avatar
You better check for a stuck injector. Is there smoke pouring out the exhaust? If so, don't run it or try to start it, you may hydrolock the engine. Could also be a bad coil on plug. More than likely it is injectors though.
Old May 5, 2007 | 10:46 PM
Rockpick's Avatar
Moderator &
Sounds like injectors to me!
Mine did the same thing.... lots of good information about the injector problems in this thread:
https://www.f150online.com/forums/sh...d.php?t=274871
