Alarm systems
Old Apr 4, 2007 | 06:11 PM
FX4ME2's Avatar
Originally Posted by wxscpo
Is it called something else because I can find no internal shock sensor in the listing of functions. Doesn't mean it doesn't have though. Is that something that can simply be disabled?
I don't think it can be disabled. Call and speak to Travis, he will take the time and explain what i mean. As far as having someone installing it, You can do it as long as you are not color blind. Fords wiring is all color coded, and his instructions are VERY VERY Clear! If you can use a screwdriver and a socket, you got it made. I would let my 13 year old Son install it on my truck! It's that easy, and goof proof! Travis usually has his cell phone on most of the time, and you probably could call him a head of time, and he would keep his phone on while you are installing it. That is why so many people here purchase his products.
Old Apr 4, 2007 | 09:18 PM
Jwool15's Avatar
i got my 791xv off shop.com for 178 and then the bypus module the directed 555u for 29 bucks. Then i got it installed for 100 bucks.. If i was you ide pay someone to install it, that way if you have a problem you can just take it to them and get it fixed. i LOVE the unit and especially the remote start!
Old Apr 4, 2007 | 10:28 PM
themetermcse's Avatar
hey wxscpo, what part of MS are you in?
On the shock sensor, it can't be disabled, however you can adjust the sensor yourself. take a precision screwdriver and adjust it. I adjust mine on the time of year it is. summer time, crooks are out moore, so I turn it to the highest sensitivity. Winter time, turn it about halfway.
Anyway, I would get the CA that you are looking at, an Ungo, a Clifford, or an Avital. For the remote start you will need the bypass and a non cut, non programmed key. Me and another guy installed mine. I have an ungo 2-way.
Old Apr 5, 2007 | 07:32 AM
wxscpo's Avatar
Diamondhead. Right down along the coast.
Thanks for the info. I have a feeling I will be giving Travis a call as soon I can scrape up the money to get everything I'm going to need.
Travis is running a special right now on the CA670. Anybody have any idea how long his specials usually last? Don't want to miss out on a good deal, but family vacation is coming up and really hate to rob from that fund.
Thanks again to all for their inputs.
Old Apr 6, 2007 | 05:48 PM
wxscpo's Avatar
Well looks like I won't be going with the CA670 because none of the shops around here can install that type. One only installs DEI systems and the other two only install systems installed at their shops. The shop that only installs DEI systems said I could bring in a Viper system and they would install it for $360. I was like $360 just for install???? Needless to say I won't be going with them.
I did get an install price of $350 for a Compustar 2 way paging system. If I bump it up to include remote start the price jumps to $500 installed. Going to check one more shop.
Old Apr 6, 2007 | 07:54 PM
Ungo, Clifford, Avital, are what I consider to be the better DEI alarms. honestdee or honestdk, on ebay, can get you any DEI on product cheaper than what they are going to sell it to you for. Especially in the area of the bypass module etc...
as well as alarms.
Old Apr 6, 2007 | 09:12 PM
FX4ME2's Avatar
Talk to Travis, It is easy as pie.....They can install that type, they just want to sell you their's... You can do the install, The instructions are simple... Hell i will even tell you how to do it over the phone if you can't get it right.
Old Apr 6, 2007 | 10:36 PM
wxscpo's Avatar
Seriously how much cutting into the wiring is there to do? I don't know squat about wiring so cutting and splicing into my truck wiring does not sound like something I want to do. Is there a way I can look at the installation manual before I think about taking something like this on? I am looking at going back to the one shop tomorrow and possibly getting the Compustar 2W900FM-AS installed. The wife has given the green light to go for it if I want it.
Old Apr 7, 2007 | 03:57 AM
DirtyDoggT's Avatar
Keep in mind that Travis's Code Alarm CA670 will tie into your door motor wires allowing you to arm and disarm the alarm system with hte key pad on your door. There is no other system out there that does that other than the Ford systems that are made by guess who......Code Alarm. Not a huge deal but is a nice feature to have.
Plus with the 670 you can add the Car-Link. This allows you to arm/lock, disarm/unlock, and remote start your vehicle from a telephone. I use mine all the time since my work building won't let my remote signal reach my truck. I just call it up with the phone and start it up. Travis talked me through how to set it up on my phone to auto-dial each prompt. Works great.
As for the wiring. Not two tough. The F150 is a very simple truck compaired to others out there. With Travis's instructions he makes it quite simple. Plus if you get in any jams or just need to confirm something he's just a phone call away. His instructions come with pictures, location and color of the wire, what it will show with a test light, what tools he recommends and even how to make your connections. He's been installing for like 16 years. Knows his stuff and customer service to match.
Old Apr 7, 2007 | 04:44 AM
je3169's Avatar
Ford gold remote start /alarm $280.00 and i installed it myself if you have a keypad you can arm and disarm through it and it comes with 2 remotes.
Old May 13, 2007 | 03:48 PM
knighj1's Avatar
I cant get the www.kcautosounds.com to pull up
Old May 13, 2007 | 04:41 PM
jrohrigj's Avatar
try www.kcautosound.com
Old May 13, 2007 | 04:45 PM
knighj1's Avatar
Originally Posted by jrohrigj
Thanks Bud!!!!!
Old May 13, 2007 | 05:39 PM
wxscpo's Avatar
I ended up going with the Compustar and am very happy with it. Everything installed, including remote start and remote paging system was $450. Now that's it's getting hotter down her eon the gulf coast it is great to be able to sit in my office and start up the truck and have the A/C running 5 minutes before walking out.
Old Aug 3, 2007 | 11:52 PM
TNoff's Avatar
Looking for an alarm. Did a search. Looks like Clifford is still making good alarms.
