max tire size
Old Mar 30, 2007 | 11:29 AM
red04f150$'s Avatar
max tire size
I am going to get the 2in leveling kit. I am under the impression i can go with a 33 inch tire. I am going to get 20s. I have a fx4 - what works out to a 33 inch tire in this format 285/65/20. I am wanting an all terrian tire. Thanks
Old Mar 30, 2007 | 11:48 AM
BalogUK's Avatar
with a 2" kit on a 4x4 you can fit 35's on the stock wheels (35x12.5R18) you can also go with a 33 (33x12.5R18) while a little too wide for stock, the 325x60R18's (33) and the 325x65R18 will also fit, but you will need to pay close attention to your alignment and your air pressure.
Old Mar 30, 2007 | 11:50 AM
05supercrew's Avatar
I have 18s with my 2'' AS. 325-60-18 which is a 33'' tire No rubbing what so ever.
Old Mar 30, 2007 | 11:52 AM
pkonnik's Avatar
33" that are common with a 2 inch levelling kit are 305/55/20
hope this helps
Old Mar 30, 2007 | 11:55 AM
red04f150$'s Avatar
thanks guys...yes it does help. I just want to make sure I have a tire that is aggressive...yet fits!
Old Mar 30, 2007 | 12:01 PM
BalogUK's Avatar
if you are going the aftermarket 20's route- stick to 33-34" max size...
Old Mar 30, 2007 | 12:45 PM
JackADF's Avatar
BalogUK.....How much 4 wheeling do you do? I'm thinking about going with 35's on my OEM 17's with a 2.5 AS. I sometimes do light 4 wheeling and was wondering how much rubbing you get?
Old Mar 30, 2007 | 03:25 PM
BalogUK's Avatar
my truck is currently covered from roof to tire in mud. it only rubs at full crank turning-
Old Mar 30, 2007 | 03:52 PM
JackADF's Avatar
sounds like you had a little fun......after reading your post and bugging several members with 35's i think i've finally made up my mind to go with 35's.....thanks for the help.
