Rafa26 Project Pictures ! Finally Done !
Did you add cams with that build, I went with comp cams stage two,I will going to the dyno when my truck hits 400 miles All i want is about 500 hp with 8 psi, Looks like you and i will be above 500 hp at the wheels ,good luck with that motor.
Originally Posted by fordabbits
Wow! That looks super clean. Very nice. So, are you going to drop in a new torq converter next, or let your bank account recover? Once again, nice job.
As you can see the TC can not survive with that power levels and now it's up to Factory Tech to honor their name and provide me a transmission and TC capable to support the engine power.
Remember that this is a break in tune and if the converter was ok, JIM Sr. told me that that he had around 50hp/80trq left on the table with the same 11psi.
My plans for after the break in period(1500 miles) is to push the envelope and run maximum boost with a safe tune for 93 octane gas. That probably will be something around 17-19PSI and 650RWHP/750RWTQ.
The new torque converter will have to be a really strong piece but that's a problem to Factory Tech now.
