6" fabtech with 2" spacer. clears 37s?
Old Feb 27, 2007 | 10:16 PM
purpony's Avatar
I am sure this has been asked over and over but with a 6" fabtech and 2" spacer, with aal, I should be a full 8" of lift?, enough to clear 37x13.5x20
Old Feb 27, 2007 | 10:27 PM
ThumperMX113's Avatar
Yes, but why not just do a true eight inch suspension lift?
Old Feb 27, 2007 | 10:34 PM
Fx4 Country Boy's Avatar
I got 37x12.50x17 when I turn real hard and go over bumps just on my extend a fender. Stock fenders flares not really shore
Old Feb 27, 2007 | 10:55 PM
purpony's Avatar
already have the 6"
Thumper... your still running stock gears- right? what are you getting to milage around town. I plan to swap to 4.56s sometime but not right away.
Old Feb 27, 2007 | 11:17 PM
etrevino103186's Avatar
how are your cv angles? mind posting a picture?
Old Feb 27, 2007 | 11:33 PM
purpony's Avatar
hey etrevino103186-
are you using a spacer and aal or not with your 37s?
Old Feb 27, 2007 | 11:48 PM
I am working on lifting the front end. I haven't quite figured out how I am going to do it. Coilovers, spacer, or adjustable shock, but I have a Sky-Jacker aal right now. I am leaning towards the spacer since I already have it...
Old Feb 28, 2007 | 01:50 AM
butter180's Avatar
I have 37x13.5x24 with just the fabtech 6" so with the added 2" you should be fine. By the way I do rub the inside of my flares only at full turns on bumps. I am also planning on adding the 2" spacer up front soon. The skyjacker 4" aal has been waiting in my garage.
Old Feb 28, 2007 | 09:54 AM
Butter, where'd you get the Skyjacker 4" leaf pack? I need to buy one. . How much did you snag yours for?
Originally Posted by purpony
already have the 6"
Yup, stock 3.73LS for the time being. . && I'm getting 13 mpg.
Old Feb 28, 2007 | 12:20 PM
butter180's Avatar
I ordered it from 4wheelparts it was $180.
The part # is SKYR3440
Old Feb 28, 2007 | 12:38 PM
Butter did you need a driveshaft extension?
Old Feb 28, 2007 | 01:49 PM
purpony's Avatar
Butler- sweet truck!
thanks all... i was telling myself this morning to stick with 35s, then i look on this forum again and want 37s, lol... stop it guys, please!
Old Feb 28, 2007 | 02:00 PM
what you should do is do a body lift, space, and an aal and do 40's
Old Feb 28, 2007 | 02:50 PM
purpony's Avatar
if it were only a perfect world i would- LOL
Old Feb 28, 2007 | 04:23 PM
Josiah's Avatar
purpony, you'll rub pretty bad without the DL coilovers, even then I'm rubbing bad so I can't imagine what it'd be like without the extra lift. Also, he has aftermarket flares, that is where you rub (on the flares). Be ready to do some trimming. I am pretty close to doing the 3" body.
