Run Sirius/XM and your iPod through the same PIE...
Old Feb 25, 2007 | 08:06 PM
BigDave4's Avatar
I just finished a quick and cheap mod. I have a Sirius Sportster hooked up to my Alpine CDA-9813 through a PIE that is plugged in my Ai-Net through a cable that looks kind of like this:
I thought is was cool that I could disconnect the 1/8 jack from the Sportster and plug it into the iPod and play it that way. It got kind of annoying pretty quickly to have to reach behind and unplug it each time, so I popped the panel off to have look. I then ran to "the Shack" and picked up a couple of RCA Y-Adapters (Single Male, Dual Female) and a Monster Brad iPod cable, which is simply an 1/8 inch to RCA cable. I just wanted to get one that was nicer than the standard "Shack" brand.
Install is simple...
Plug the splitters into the PIE RCA.
Hook the Male RCAs from the Sirius to the red and black splitter
Hook the new iPod cable into the red and black splitter
Turn on whatever you want to use, iPod or Sirius and play away through your HU!
All in all, I got out of there for about $28. On the way home I stopped by the local Ace hardware and picked up a rubber grommet and headed home to install everything. About 30 mins later, I was done. There are a few pics in my gallery. Here are some of the highlights...
Here is what I had to buy...
Old Feb 25, 2007 | 09:54 PM
02SuperCrew4X's Avatar
Nice writeup. I did the same in my '05 Lariat a year or so ago. Not sure if I posted about it on these forums tho.
Old Feb 26, 2007 | 02:09 PM
lawclerksfv's Avatar
do you have pics of the actual hook up to the PIE. I am trying to do the same thing but I do not think i am doing right.
Old Feb 26, 2007 | 02:18 PM
BigDave4's Avatar
I don't, but I can probably help you. Do you have IM? It's probably something simple that it missing.
Old Feb 26, 2007 | 02:49 PM
sent you a PM
Old Feb 26, 2007 | 03:08 PM
BigDave4's Avatar
Originally Posted by lawclerksfv
sent you a PM
Didn't get it. Can you resend.
Old Feb 26, 2007 | 03:38 PM
resent:
Hi,
Thanks for taking the time.
I have the PIE with the red and black input w/ the stock radio, currently have the ipod playing through the pie.
how do i connect the Y adapters to the PIE so i can alternate between the xm and ipod thru aux...
any help is appreciated.
Old Feb 26, 2007 | 04:26 PM
BigDave4's Avatar
resent:
Hi,
Ok.
You will need two Splitters with a single male end and two female ends.
Plug each of those into your PIE Red and Black.
Plug the cable for the iPod into one end of the red and one end of the black.
Plug the other device (XM/Sirius/whatever) into the open ends of the splitters.
It should work perfectly. It did for me. I am not on a stock radio, but I am going to assume that it wouldn't matter much.
The catch is that whatever device you are not listening to should be powered off while listening to the other.
Hope this helps.
Dave
Old Feb 27, 2007 | 12:22 PM
Ok.
Hope this helps.
Dave
thanks alot dave, i got the parts, will play with it after work tonight to see if it works!
