What kind of leveling kit is preferred?
Old Feb 18, 2007 | 08:11 PM
DTheobald's Avatar
I want to put a leveling kit on my truck and don't know the name brand or what size to get to level it out. I am a girl so the install will be professionally done, but I heard there is two kinds... metal or poly... what is the main difference? Where would I buy this mod at? and how much is it going to run me?
I have a 2007 Fx4 pretty much stock right now
Thanks for any help
Old Feb 18, 2007 | 08:36 PM
BalogUK's Avatar
autospring (metal) daystar (poly)
the daystar requires spring compression to be installed. the autospring bolts to the top of the coilover assembly.
i would say that the majority of leveling kit users here are autospring. they list thru ebay: http://search.ebay.com/_W0QQsassZsprngbender
install should run you 50-125 then you need an alignment.
im running a 2.5" autospring.
Old Feb 18, 2007 | 08:49 PM
taterthedog's Avatar
Revtek.
I have a 2" Revtek leveling kit. It goes inside the coilover instead of on top. Basically it preloads the spring. I prefer this to putting something on top of the coilover because it doesn't add any length to the strut eliminating the possibility of interference with the upper control arm as some have reported. The downsides are it is more labour to put in because you have to disassemble the strut, and also your ride may be a bit stiffer because you are stiffening up the front springs. I haven't installed any different kinds but I believe the Autospring goes on top, but the Daystar puts a bit on top and a bit in the spring. Also I believe the Autospring now is revised to eliminate the contact some have had with the upper control arm.
Old Feb 18, 2007 | 09:02 PM
Voodoochild's Avatar
I just had the 2" AutoSpring installed on mine, now it looks like it supposed to look. I called the guys at autospring and they recommended the 2 inch over the 2.5 inch for my truck. I noticed you have a 2007, If I remember right they said something about ford changing the strut assembly on the 07 model. Something about it being tapered ?
Before you order a set, give them a call and ask them about the 07 issue.
Auto Spring Corp
8007 W Mossy Cup
Boise Idaho 83709
Monday - Friday 8:30 am - 5:30 pm
Phone:1-208-362-0431
Toll Free: 1-800-345-0431
Email: springsNO@SPAMautospringcorp.com
Good luck with your truck... and good choice for a first mod...
Old Feb 18, 2007 | 09:08 PM
NASSTY's Avatar
I installed the 2"AS on my truck.It only took about 2 hours to install.I see they went up a few bucks since I bought mine.I paid $84 shipped for the 2"AS and $40 for a front end alignment.
Old Feb 18, 2007 | 09:21 PM
-TXF150-'s Avatar
I would go with the bilstein 0-2" 5100's...
Old Feb 18, 2007 | 09:24 PM
DTheobald's Avatar
How much are they running?
Old Feb 18, 2007 | 09:34 PM
DTheobald's Avatar
If I plan to lift my truck... this mod doesn't get in the way does it...
Old Feb 18, 2007 | 10:24 PM
Tuff4rd's Avatar
I payed $380 shipped F+B from a vendor on Ebay.
BTW I had Daystar 2.5 spacers prior to swapping them out with the 5100's
Old Feb 19, 2007 | 01:19 AM
hmfic's Avatar
How much height did you lose?
Old Feb 19, 2007 | 02:01 AM
DTheobald's Avatar
http://www.suspensionconnection.com/...0.html#ITEMIMG
Would this kit do?
Or is this one better?
http://www.suspensionconnection.com/...ml?id=VrkpsQxs
Old Feb 19, 2007 | 02:23 AM
jrohrigj's Avatar
I have the 2" tuff country installed on my truck now.
just remove your 2" blocks out of the rear for now, save your CV axles from damage until you have money for tires/lift etc
Plus then your lift will seem like you are going up that much higher, then if you have a 2" level then get a 6" lift installed
Old Feb 19, 2007 | 09:39 AM
goldmember's Avatar
I'd go for the autospring. Preloading the coil is going to lead to premature fatiguing of the coil and causing front end sag over time. I think the cv's have better ability to compensate for the lift then the preloading of the coil spring.
Old Feb 19, 2007 | 11:43 AM
gilsnuxs's Avatar
[QUOTE=DTheobald]http://www.suspensionconnection.com/...0.html#ITEMIMG
Would this kit do?
This looks lik ethe procomp kit that I ordered from Summit, for a lot less than $132. Mine has worked fine.
