Anybody have mushy brakes/bad master cylinder?
The brakes on my truck suck. Everytime I hit the brakes the pedal goes down way more than normal and they feel really mushy. However if I pump it one time the pedal comes right back to the top and the brakes feel great. So now everytime I start to brake I pump them one time to get them to feel right.
Its still under warrenty so I took it in to the dealer and they said it was normal.
Even after arguing with them that my truck had had classic symptoms of a bad master cylinder,they insist that its normal.
My question is,has anyone else had this problem or had a master cylinder replaced?
Andy
Even after arguing with them that my truck had had classic symptoms of a bad master cylinder,they insist that its normal.My question is,has anyone else had this problem or had a master cylinder replaced?
Andy
I had/have the same problem, took to the dealer several times. They finally replaced the entire master cylinder/brake booster assembly. Even with the new parts brakes still mushy at times and brake pedal goes to the floor with ease, its scary at times.
My brakes feel the same way. Soft pedal with lots of travel before you actually start feeling it grab. I thought it was normal for these trucks until seeing this post. Anymore input from other member would be appreciated.
I remember a post a while back about this and the fix was something like letting your truck set overnight with the brake fluid cap off. Don't ask me why it worked, but i think it fixed it for him.....
i had asked he dealer teh same ting about my brakes on my truck i have only about 8000 mile eon my truck and take it in every three months for my free oil change and everytime i take it in they alwasy say we had to fill your fluid in your master cylinder and the last tiem i asked how is it that you are filling it up every time they told me its normal to lose fluid like that
That guy is full of crap! You dont lose brake fluid unless there is a leak.
Andy
You don't really lose fluid (unless you have a leak), but the fluid level will go down in the reservoir as your pads wear.
If you keep adding to your fluid, when the pads are changed the reservoir will probably overflow.
The brakes on my 06' have felt very soft and mushy from day one. I was told by a guy that the newer fords are designed that way for some reaon. They have a softer pedal to decrease touchiness. I hate the way they feel, and I guess that I will try to cap off the resovoir over night. Everyone that drives my truck comments on the brakes and how soft and weak they feel. The truck will stop on a dime if you need it to, just the pedal is very soft and seems to fade on every stop.
Please post the fix to this if anyone finds it, my '05 does it. But the wierd thing is it only does it sometimes, maybe 60-70% of the time that I drive, the other 30-40% of the time they feel great
But when it does it I can pump the pedal once and they will tighten up and feel fine. I dont think this is normal, because my wifes '06 doesnt do this, her brake pedal is firm at all times, never mushy. I played it off in my truck to the fact that I have towed my bass boat many miles and figured it had just caused excessive wear in my brakes even though I do have trailer brakes on the boat, but after reading this post it makes me think there is a fix. I hope its nothing expensive, because my warranty has been gone for about 12k miles
My 06 screw lariat 4x4 has the same brake symptoms as most posts here. has 17k miles and brake pedal feel like MUSH , truck always stops ok , but I feel something is wrong. Master cyl has never needed any fluid , Someone please post a solution , as dealer says pedal feel is normal.
