question
Old Jan 23, 2007 | 07:18 PM
shoeynne's Avatar
question
which is better to have for winter driving a 4x4 or a differantal lock.i don t do any off roading at all looking into a ford again .and also looking to move up to the northeast.so what does everyone think?thanks
Old Jan 23, 2007 | 07:27 PM
BalogUK's Avatar
got 18" of snow the other night while skiing- 4x4 worked perfectly in conjunction with the stock limited slip rear differential-
i live up here in montana, and we are snow-covered from mid october thru mid april- 4x4 is all you ever need for standard operation
cndcowboy's Avatar
4x4, NOT the lock. A locked axle on snow and ice will cause you to have your rear end slide out on you easier.
Old Jan 24, 2007 | 01:27 PM
shoeynne's Avatar
any one else?have there opinion
Old Jan 24, 2007 | 01:32 PM
a n t h o n y's Avatar
Banned
cndcowboy summed it up for you. If you have LS just take it easy in the turns. Unless you want to have some fun w/ risk.
Old Jan 24, 2007 | 01:33 PM
Tbird69's Avatar
I have 4x4 with a limited slip in the rear and that provides me with everything I need to cope with the winters where I live. 4x4 gets me through even the heaviest storms that blow through here, while the LS keeps me moving when there isn't enough snow on the road to justify using full 4 wheel.
Old Jan 24, 2007 | 01:34 PM
Tbird69's Avatar
OH YEAH!!!! Here fishy, fishy, fishy!!!
Old Jan 24, 2007 | 01:47 PM
speedwolf's Avatar
I've found that the 4x4 with the limited slip works the best in the snow. My 04 that I traded in had the open diff and I hated it in winter.
Old Jan 24, 2007 | 11:46 PM
chris1450's Avatar
just limited slip is a BAD idea in slipery conditions. 4X4 all the way if you want piece of mind.
