Installing a Alarm
Old Jan 25, 2007 | 01:25 PM
jdoggfx4's Avatar
Okay so I just need to order the one from travis that has what i want and get it pre-wired and is should be an easy install after that?
Old Jan 25, 2007 | 01:50 PM
JerryK's Avatar
Let's not make this sound too easy: Its not a plug-in harness. you need decent preficiency in wiring, you'll need a volt meter to test a couple of circuits, you need confidence in taking apart your interior panels and reinstalling them, you need to be good at stripping wires without cutting copper, you're better off if you know how to solder, you'll need to run a wire or three through the firewall and one to the bed (for injector, the hood pin, the siren, and the tonneau trigger.. all are optional). If these things scare you, you're better off going to a someone that installs Code Alarm products and getting a Code Alarm unit put on your truck.
Old Jan 25, 2007 | 01:52 PM
jdoggfx4's Avatar
Nope sounds good I have put in many a sound system back in the day I just want to make sure that it is well documented and that the degree of diffculity is not to bad
Old Jan 25, 2007 | 02:11 PM
JerryK's Avatar
Ah, you should be good to go!
