What is this?!?!
Old 01-06-2007, 06:46 PM
JonnyT's Avatar
What is this?!?!
Okay can someone tell me what this is on the support beam? You are looking at the radiator (I just put some screen in front of it. I am asking what those 2 items are attached to the center beam.
Old 01-06-2007, 06:58 PM
mwheue's Avatar
I beleive one of them is the airbag/impact sensor and the other might be the temp sensor for your outside air temp gauge. But that is just a guess.
Old 01-06-2007, 07:31 PM
JonnyT's Avatar
okay, same topic. In the cab on the panel with the cigarette lighter there are 2 wire harnesses clipped into that panel. I am assuming one is the reverse sensor? not sure. But what would the other one be?
Old 01-07-2007, 01:33 AM
SnowmaNick
Guest
Posts: n/a
I think thats for the traction control, that's where the button for mine is located at least...
Old 01-07-2007, 01:38 AM
BalogUK's Avatar
hey JonnyT- could the second harness be for the mirror heat switch?
off topic- what part of MT are you in? welcome!
Old 01-07-2007, 02:37 AM
bushtree's Avatar
like stated one of those is the outside air temp gauge. Im not sure what the other is..
Old 01-07-2007, 03:17 AM
upper should be ambient air sensor
Old 01-07-2007, 04:58 AM
JonnyT's Avatar
I have the heated mirrors in the top along with the Recircl, and AC. so i am guessing backup sensor and air temp/direction for the other. guess it doesnt matter that i put my toggle switch there. So I had to do a lil grinding.....
BWT I am in Great Falls balogUK, u were the reason i chose roush off road from woodhouse. Thanks
Old 01-07-2007, 09:38 AM
dinlong's Avatar
as stated the top one is your ambient temp sensor, the bottom one is your front crash zone sensor. The harness with the green connector (8 pins I think) is for the backup sensors. Not sure about the other one though (my truck doesn't have that one). It will be fine to put a switch in that panel. I put the button for my train horns as well as a power switch for my air compressor there.
Old 01-07-2007, 11:19 AM
CANNONFX4's Avatar
Dinlong, do you have any pictures of your train horn setup?
