Engaging 4 wheel drive
4 wheel drive always engages flawlessly when driving but seems to have issues and noises when engaging 4 hi from a stop. I know that the manual says to engage it while moving forward but that might not always be possible. It makes a lot of clunking noises then finally engages when I hit the gas after more clunking noises and then its fine. Im in Colorado and have been needing 4wd a lot the last 2 weeks including another 8 inches of snow today.
Im just wondering if this is normal - this is my first Ford and my Toyota never made a peep or had any hesitation going into 4 wheel.
i do mine moving or stationary- doesn't matter- the more you use it, the less you will get the clunk- mine hardly ever clunks any more. if i know the 1/2 mile long driveway is going to be slick on the way down i'll throw it in 4h before i go into drive- or if im half way down and decide i need it i'll flip it over on the roll.
it can engage up to 50 mph i believe.
4L def needs to be in neutral- i will get a little bump when it locks in though...
My problem is that it is in 2 wheel in the garage and then I back out through a foot of snow through the driveway and as I start to go foward on the street is when it gets stuck and thats when I have to engage from a stop.
actually, yep today when i was at the post office in town was in 2wd reverse, wasn't getting anywhere fast so i flipped it to 4h- give it a couple seconds to engage and im rolling again-
if you are actively slipping/spinning, ie the front or back don't have traction, 4wd will not engage- but if there is friction-ie forward/backwards movement, or just sitting it should lock in withing a few seconds of flipping the switch
I do believe the shop manual says.. the computer won't ingage 4h unless you are doing 15mph or less and 4l if your doing 5mph or less
