Question for Autospringers with camber kits
I recently installed a 2" AS kit in my '05 2wd reg cab, took it to get an alignment and the shop couldnt get it into spec without putting a camber kit in. Well after them ordering and installing the kit I have now noticed that my front wheels seem to set in more than they used to. Other words what has happened is when I installed the AS kit it caused my front wheels to be toed in at the top and out at the bottom, evidently this camber kit brought the bottom in resulting on moving my wheels inward a 1/2" or so. Its something that nobody else might not notice when looking at my truck, but I do and it bugs me. Just curious to know if anyone else has noticed this and if anyone has put some sort of wheel spacers on to offset this. BTW, I have FX4 18" wheels with 275/65/18's, looking to go up a size or so when these wear out so it may be something that with wider tires wouldnt even be noticeable.
Doesn't sound like the re-aligned it properly. I have never heard of anyone using a camber kit with the spacer lifts but yours is a 2wd so not sure on that. If it looks like it isn't aligned properly then take it back. If the bottom of the tires are farther in then the top then you got positive camber. The opposite of that is negative camber.
well that wasnt the case with mine, they did what they could to get it into spec but it just wouldnt. I'm not alone, i have read other posts on here where guys had to have kits put in. But thats beside the point, not what I am asking about here.
well I appreciate the help then, bud
just trying to keep the thread on track, if I hadnt of cleared it up in no time there would of been 10 posts arguing over who had to have a kit and who didnt and thats not what I am wanting to know. I know for a fact that my truck needed a kit, dont know why but it did, so whether or not someone elses truck didnt need it doesnt really help me or answer my question.
Kspencer, what do you mean about "because of the weight"? You mean the added rotational weight to the wheel/hub area or because of the weight of the vehicle its self?
I couldnt tell you how much it raised mine, I didnt think about measuring until I had already started the job
But I am guessing somewhere in the 2" range. I do know that its 39" to the bottom of my front fenders now, I had measured my front end height a while back when I was trying to decided about getting the kit and the best I remember my stock height was around 37". I dont think the weight of the trucks has anything to do with how much lift you get out of these spacers. Your springs are going to have the same amount of preload and travel to them before the AS install as they will after the AS install.
I'm still wondering what you mean by you wouldnt use any kind of wheel spacer because of the weight?
But I am guessing somewhere in the 2" range. I do know that its 39" to the bottom of my front fenders now, I had measured my front end height a while back when I was trying to decided about getting the kit and the best I remember my stock height was around 37". I dont think the weight of the trucks has anything to do with how much lift you get out of these spacers. Your springs are going to have the same amount of preload and travel to them before the AS install as they will after the AS install. I'm still wondering what you mean by you wouldnt use any kind of wheel spacer because of the weight?
Like I said before, if it looks out of alignment then take it back or take it to the dealership. If the bottom of the tire is closer in then the top then it isn't aligned correctly. After I put a spacer lift on my tacoma I had the same issue. The bottom was closer in, positive camber, took it to the dealership and had it realigned.
