Which lowering kit to go with?
Originally Posted by GB150
I'm looking for a kit to lower my 2004 SCREW 2" in the front and 4" in the rear. I had been set on the McGaughy's kit but I've read of a few people on here w/ that kit that have broken leaf springs due to wheel hop w/ that kit. Then I was thinking DJM but then read today that Azmidget91 has has had issues due to wheel hop. So I have a feeling it has more to do w/ lowering the truck than any specific lowering kit. I can fab up some traction bars So hopefully I can avoid those issues. My question is, for those of you w/ knowledge about lowering kits, what kit do you suggest and what is a good price/place to buy from? I would really like to keep the factory ride as much as possible. I know altering the suspension is obviously going to change it but still, I'd like to keep a fairly "cushy" ride. I've been searching the net and prices seem to be all over the place. I'd rather spend a bit more for a better kit than save a few pennies now and suffer for it later down the road.
1.Sold by Ford and also used as OE on some of their applications.
2.No warranty issues
3.Low amount or NO problems when INSTALLED CORRECT
I have the GF 2/5 drop kit and I like it. It looks good. Maybe about 1" higher in the front than the rear, but that's fine.
Mine actually broke, but that's cause I drive my truck a little harder than most (not incorrect installation)
It was an easy install too. Took me about 8 hours to install by myself.. with alot of stops for resting.
After I finished, I took it to get aligned by my favorite mechanic. He looked at the instructions and then looked over the truck to make sure everything was correct and tight.
Originally Posted by MosineeFX4
azmidget91,
Do you have the DJM 2-1/2in drop arms up front? If so, did you have to trim the tie rods? The directions on the DJM site indicate that you have to do it for the 3-1/2in arms, but says nothing about the 2-1/2. I have been leaning this direction to retain the stock ride quality. Also, did you have to get the cam bolts for the alignment? Overall, what is your opinion of the product?
I think i'm going to go w/ the DJM for the front because I want to retain the stock ride as much as possible. Does DJM have a 4 inch drop leaf spring for these trucks? I have never been a big fan of flip kits.
Originally Posted by Sleestak
I have the Eibach Pro Truck kit. 2/4 drop with coils in front and new leaf springs in back. I just installed the Toxic drop shocks and the ride is very nice.
Is anyone w/ any kit, regardles of manufacturer having to buy anything additional to get the alignment back withinn spec? When I do this I just want to make sure I have all of the needed parts to get the truck back on the road w/o having to order more parts and wait. Thanks for all of the help so far, I appreciate it.
I've been trying to price these kits and the prices are all over the place. Anybody have any favored places to buy either, the McGaughy's 2/4, Eibach 2/4, Ground Force 2/4 or the DJM 2.5/4? Like I said the prices I'm finding are all over the spectrum.
If you use 2" coils you will need the camber kit to align the vechicle properly. No way around it, I guess Mcgauhty is the only one nice enough to mention it.
-Patrick
-Patrick
You need an alignment for the toe.
I ordered the DJM 2.5/4 kit from stylinconcepts last week for $600.00 if that helps.
If anyone is looking for a set of DJM 2.5" drop A-Arms, I have a set new in the factory boxes up for grabs. E-mail: mwheue@comcast.net
im looking at the belltech 3/5 now, i want it low and leveled. anyone have this kit or know someone who does. guy i know in tx has a 3.5/5 djm kit and said he had problems with it and had to weld bolts onto the arms b/c they kept backing out. not sure what he meant but he said the kit sucked *** b/c he had to make it work.
