Help with 4x4
Old Nov 18, 2006 | 05:10 PM
BlackMax's Avatar
Help with 4x4
I have an 2004 F150 lariat 4x4. Today, I needed to pull my tractor out of a ditch, so I used my front tow hooks, put it in 4L, then reverse and slowly pulled the machine up the hill in reverse. It worked perfectly.
The problem is that I now cannot get it out of 4L. I turned the switch to 2H, put it in reverse, and it is stuck in 4x4. I tried backing up 20 feet, nothing. I need to get it out of 4L.....any suggestions? Has this happened to anyone else?
Old Nov 18, 2006 | 05:18 PM
weazel's Avatar
Registered User
switch form 4x4 low into 2H, when the truck is in neutral!
Old Nov 18, 2006 | 07:11 PM
TexasFatboy's Avatar
and foot on the brake
Old Nov 18, 2006 | 07:32 PM
allrsdup's Avatar
yes truck should be in neutral when u go in and out of 4x4 lo
Old Nov 18, 2006 | 09:57 PM
BlackMax's Avatar
Neutral with the brake on did the trick. Althought there is some lag time...you need to wait a bit for the light to go out and the tranny to disengage.
Thank you to all that offered advise !
Old Nov 18, 2006 | 10:18 PM
bushtree's Avatar
yep. the delay is normal.. it takes a second or some for the disengage to happen..
Old Nov 19, 2006 | 09:52 AM
Tbird69's Avatar
How did you put it into 4 LOW? It's the same operation to turn it off.
Old Nov 24, 2006 | 12:05 AM
jmhoff's Avatar
I noticed if you have it in neutral, foot lightly on brake *and* you are rolling forward at 1 MPH or less, it goes in and out easier. Any more than 1 or 2 MPH and you'll get a clunk.
Old Nov 24, 2006 | 12:41 AM
Josiah's Avatar
What does ur tractor weigh?
