Guess the Dyno #'s on this Tuned F150
Old Nov 18, 2006 | 01:49 PM
  #31
BalogUK's Avatar
awesome duke! man i wish there was a dyno around my neck of the woods
Old Nov 18, 2006 | 01:50 PM
  #32
F150 Duke's Avatar
Thanks. Now I'm just trying to figure out how to post the screen shots of these graphs from the dyno viewer as you can't save the graph in the dyno viewer.
Duke
Old Nov 18, 2006 | 01:53 PM
  #33
BalogUK's Avatar
can you export to a .jpg? if not, maximize it as much as you can, press "prnt scrn" on your keyboard, then in paint or any program, press paste, and it will paste the screen shot... save as a .jpg, then upload to your gallery
Old Nov 18, 2006 | 01:59 PM
  #34
PHS79's Avatar
Nice numbers!!!
Originally Posted by F150 Duke
Well nobody guessed both but PHS79 guessed hp and was off on trq when he guessed 305.
Well, one of two isn't bad.
I just might have to make an appointment to get my truck dynoed there when I am on my way to St. Cloud in a couple of weeks. Since there is no place down here with a dyno, or at least no place that I know of.
Old Nov 18, 2006 | 03:42 PM
  #35
F150 Duke's Avatar
Originally Posted by PHS79
Nice numbers!!!
Yeah I figured out how to post the graphs and will put them up in a minute.
PHS79, send me an email or PM when you plan on going to the dyno in Elk River. I'd like to meet up with you and watch the run.
Thanks,
Duke
Old Nov 18, 2006 | 03:54 PM
  #36
F150 Duke's Avatar
HP:
TRQ:
A/F:
Speed:
Old Nov 18, 2006 | 04:04 PM
  #37
cobraman302's Avatar
Nice numbers Duke, little higher than mine. I would have guessed clode to that considering the Troyer seems to make better numbers even on a 91 octance tune. I was at 254hp/326tq with the edge on level 3 with MAC catback, and airaid Jr. Nice Truck also. Rich.
Old Nov 18, 2006 | 04:27 PM
  #38
rms8's Avatar
In the 3rd gear pull:
HP – 257.49
TRQ- 329.81
I'll try and do a screen shot of the graphs to show you guys.
Once again the mods are:
3.25" AF1
Magnaflow SIDO catback with a magnaflow resonator
TP 91 Octane Tune
5.4 3V V8 2005 4WD 3.73 LS
A/F ratios were off the charts rich so I'll be sending this to Mike for additional tuning and maybe we'll be able to get a little more out of it, but these numbers are still really good.
Conditions:
65.49 degrees Fahrenheit
29.10 in-Hg
Humidity: 10%
SAE: 1.00
Duke
I took screen shots of the graph and am just trying to figure out how to save the screen shots as jpgs to post them.
Hey guys,
You made 257hp to the tires. To put things into perspective, one must take into account 17-20% parasitic drag due to accessories and automatic tranny. This equates to roughly 310-321hp at the Flywheel. The motor is already rated at 300 flywheel HP from Ford.
So all the mods netted a max of 10-21hp.
Just FYI.
Curious to see what the $$ to HP-gained ratio would be?
Has anyone chassis dyno’ed a stock motor?
Old Nov 18, 2006 | 04:43 PM
  #39
PHS79's Avatar
Originally Posted by rms8
Hey guys,
Just FYI.
Actually these trucks have around 30% drivetrain loss (if 4WD). Most bone stock trucks are in the 200-210rwhp range.
Old Nov 18, 2006 | 04:46 PM
  #40
F150 Duke's Avatar
Hey guys,
Just FYI.
There are a couple threads in the chips forum where 04+ F150s with the 5.4 and 4WD dyno at 210 at the rear wheels.
So I gained 47 at the rear wheels and should be able to get a little more after fixing the rich A/F ratio.
There isn't a big difference on these motors between the 87 oct tune and 91 or 93 oct tune. They have a hard time taking advantage of the higher octane. Usually less then 5 HP difference. That's what Mike has seen as well as the tuner I was at.
Duke
Old Nov 18, 2006 | 04:53 PM
  #41
smokestoneF150's Avatar
You said it Justin
Nice numbers though!
Old Nov 18, 2006 | 04:55 PM
  #42
Hey guys,
Just FYI.
Thats not even close. Its more like around 30% loss unfortunately. Thats one big downfall of these trucks, a lot of power is lost through the drivetrain. ANd you should always go by a base run, not some generic 17-21% loss. Every truck is different.
Old Nov 18, 2006 | 05:03 PM
  #43
rms8's Avatar
30% parasitic loss!!!!!! (I would have used the big eyed icon, but for some reason, they don’t seem to be working???).
Is this a well known fact with Ford automatics? That seems extremely high. Considerably more than I would have ever guessed. If that’s true, then it’s a down right shame!
Old Nov 18, 2006 | 05:08 PM
  #44
Rockpick's Avatar
Moderator &
I'm going to guess 257.49 / 329.81
What are the numbers Duke?
Old Nov 18, 2006 | 05:19 PM
  #45
F150 Duke's Avatar
LMAO! RP won!
What a guess, how did you do it?
Yeah fellas, the loss on our trucks is substantial. Dodge isn't much better, same with GM. Nissan has the best % of us all and puts more to the rear wheels then the Hemi Ram. I remeber reading in the tuning forums that Rams put 240 to the rear wheels and Titan puts 260 to the rear wheels.
Duke
