truxxx 3"??
truxxx 3"??
well i was thinking about changing the ProComp 2.5" Leveling Kit for the Truxxx 3" Leveling kit, wat do u guys think? i really hate the way my truck got lower in the front just a few weeks after installing it so id like the leveled stance permanently. keep in mind i already have my body lift just havent installed it yet, NO TIME. should i just wait after the body lift is installed to see wat it looks like, or get the truxxx??
If it was me, i would wait. The truxxx kit, from what i understand is expensive and isnt worth the extra 1/2 inch. Also, it will ad more stress to your cv angles and tie rod ends. Put the body lift on and see what you think of it then. If you dont like it, replace the pro comp with an autospring kit.
Originally Posted by TonkaTruck33
truxx is a leveling kit that is 3" not the 2.5",
casey, thankz yea thats probly wat im gonna end up doing.
do not do it, 2.5" is bad enough no way i would do 3"
Originally Posted by allrsdup
no way
do not do it, 2.5" is bad enough no way i would do 3"Trending Topics
Originally Posted by rojoscrewkab05
i have the truxxx 3 inch.i like it but i wanna save up for a bigger kit.check my pics if you wanna see.btw its 2wd
my god lok at those lower controle arms that loks sever to me id love to see what your upper controle arms look like. with that setup u have no negative mobility left in your suspension that is not good for your truck, good thing it is not a 4x4 it would be worse.
the uppers look ok but i can see where i have rubbed the coil a little bit.I have debated with my self when the tires go my spacer goes and try and save money for a real lift kit....wanna see what the edge does on stock tires level 3.
