Intake??????? Help Me
Old Oct 18, 2006 | 08:59 PM
niceasssupercrw's Avatar
I know this topic is prob beaten to death but whats the best intake for the 5.4s. I need something reliable that wont throw any lean codes. Any help would be appreciated Thanks
Old Oct 18, 2006 | 09:26 PM
06FX4's Avatar
i think your best bet if yout getting a tuner is the air raid!
Old Oct 19, 2006 | 12:33 AM
mkinttrim's Avatar
Volant and Edge here, works great!
Old Oct 19, 2006 | 01:20 AM
Truspeeder205's Avatar
I have the Air raid with the throttle body spacer and the Edge and its great no problems what so ever
Old Oct 19, 2006 | 08:46 AM
MGDfan's Avatar
Hi.
Just an FYI -
> not all lean conditions throw codes
> Some 2004 & 2005's run too lean from the factory
> Edge cannot correct for MAF-related lean conditions
> Volant chokes at high rpm's (above 4,000 rpm)
> AF1 has been tested to provide the most gains
> custom tuning with datalogging is the only way to make certain the intake is not causing issues - everything else is just guessing. Period.
<Boilerplate On>
ALL of the above was distilled from previously posted material. Just reporting what's been discussed in detail already. You may want to Search to find out more - you choice.
<Boilerplate Off>
Cheers
Bubba
Old Oct 19, 2006 | 12:52 PM
gatkins94's Avatar
I have the volant and edge......unless I can get that "Drone" reduced, I would NOT recommend that intake. I've sent the tech support an email hoping they will eventually respond, but until then.....I can't recommend it.
Old Oct 19, 2006 | 01:14 PM
anaheim's Avatar
Originally Posted by MGDfan
Hi.
Just an FYI -
<Boilerplate On>
<Boilerplate Off>
Cheers
Bubba
These are the reasons i personally am keeping my stock intake on my truck, I have also read that the intake alone does not provide any noticable increase in power.
Old Oct 19, 2006 | 01:16 PM
rojoscrewkab05's Avatar
I too am getting sick of my volant intake.The drone is killing me.I screwed the box down,i have laid dynomat down.Im thinkg of getting the aem or back to stock.I also have the edge on level 3.
Old Oct 19, 2006 | 02:01 PM
Silverfish's Avatar
Hi.
Just an FYI -
<Boilerplate On>
<Boilerplate Off>
Cheers
Bubba
I think you guys are going overboard on this lean issue........Bad fuel can make you run lean. I have read were Mike has said that our engines can run up to 15% either way of the octane grade. The Edge tune or factory tune or Mikes Xcal II tune can run lean (no datalog) within the 15% and still be ok. If you want the maximum performance then get a custom tune and datalog to get rid of any small amount of a lean condition.
Old Oct 19, 2006 | 09:55 PM
Adam06FX4's Avatar
Registered User
just get the airaid jr. and you will have nothing to worry about
