Bed Rattle
Bed Rattle
I have been hunting this week and driving down a lot of logging roads. When I hit a real bumpy patch something is making a bad rattle noise from the back of the truck. It sonds like my tailgate is loose but when I look at it it seems tight. I have the frame dampener on it but that doesnt look like the culprit either. I will try to get someone to ride back there so I can pinpoint it but I was just wondering if anyone else has experienced this. Thanks, It is embarrassing to have my new truck sound worse than mt 72 f-250.Oh and by the way the spare tire is tight, Thanks.
Are you sure it is the bed and not the jack? I notice you have a SCREW and the jack under the back seat can get loose and make quite the racket when it is gets bumpy...
I was crawling all around the back seat of mine before i figured out that the jack was loose and metal parts were banging on the seat brackets.
Thanks, I have a spray in liner and I checked the jack because I actually took it out to make sure the spare was tight. The noise is loud rattling like something is loose and I dont think it should happen. I am going back up this afternoon and will see if with some help I can isolate. Thanks.
Here are several threads about squeaks coming from the rear of the truck, it might be the same thing you are encountering:
https://www.f150online.com/forums/sh...d.php?t=232080
https://www.f150online.com/forums/sh...d.php?t=230140
https://www.f150online.com/forums/sh...d.php?t=208447
This solved a buddy of mines squeak in his '06.
Thanks Monkey for your help but mine is much more than a squeek it is a loud rattle like the tailgate is gonna fall off but everything is tight. It doesnt happen on all bumpy sections just some. I will find it.Thanks
Make sure your spare is cranked up tight. I have had them make noise before when they weren't quite cranked up all the way.
I guess its possible. The tailgate is easy to take off, drop the tailgate and disconnect the straps and then lift it a little over halfway like you are going to close it and then pull out in the passenger side.
